Highlighted
Beginner
Aironet 1602e on 2504 Controller
I was wondering if there was a way to include additional AP configuration information on the controller.  I'm trying to program the following on some Aironet 1602s:
1.  Program the timezone to Eastern
2.  Program daylight savings to EDT (recurring)
3.  Program the correct antenna DBi information
I know this is a bit trivial, but I'm a little picky.  I can program this info, but every time an access point is restarted, the info is lost.
Mike R.
2 REPLIES 2
Highlighted
Hall of Fame Community Legend
Once you configure the Country and the timezone, DST would be automatic.
Go to Wireless > Access Points > Radio > right-hand of the AP and choose "Configure" > go to "Antenna Parameters" and enter the value under "Antenna Gains".
If your antenna is, for example, 4 dBi then the value entered is "8".
Highlighted
I forgot to mention, the controller is running 7.4.0.60 firmware.  I tried looking into the wireless settings, but I didn't see it.
The antenna DBi is entered for both radios (2.4/5 GHz).  I know you can set it in the CLI, but I couldn't find it on the 2504 controller.  Any chance you can throw a couple of screen shots?
Thanks.
