233
Highlighted
Beginner
Aironet 2600i Throuput issue in 2.4 GHz
Hi everyone.
recently we increased Internet speed up to 200 Mbps. through 5GHz Radio and LAN, I can get the 180 up/down the speed. but on 2.4GHz, still, it's 98 Up/Down.
does anyone have suggestions?
Everyone's tags (4)
3 REPLIES 3
Re: Aironet 2600i Throuput issue in 2.4 GHz
Hi @helpling
Your configuration looks fine, not sure if you are using channel bonding on 2.4 GHz, still, if you use bonding you will have an issue with your plan channels. I think this is a physical limitation on the 2.4 GHz band.
Beginner
What device are you using to connect on to the 2.4 GHz?
Hi @JAYESH RAMAIYA
I always follow "Cisco Wireless LAN Controller (WLC) Configuration Best Practices"
In general, Disable low data rate, use 20 MHz width, if you're using PSK then use WPA2 with AES-CCMP.
Content for Community-Ad
August's Community Spotlight Awards
