03-14-2018 01:40 AM - edited 07-05-2021 08:22 AM
Our switch, WS-C3750X-24P running 15.0(2)SE4, keeps Reporting Duplex mixmatch With most of Our 2800 AP's;
Mar 14 09:32:18.338: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/14 (not half duplex), with XXX_AP3 GigabitEthernet0 (half duplex).
Mar 14 09:32:21.786: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/16 (not half duplex), with XXX_AP6 GigabitEthernet0 (half duplex).
The WLC (Cisco 5508, sw 8.3.140.0) reports speed 1000 and Duplex full. The switch also reports a-full and a-1000 on the switchports. I can only assume that this is a bug somewhere..
01-17-2019 04:07 AM - edited 01-17-2019 04:11 AM
We're getting this on both Catalyst and Small Business switches, the WLC is running 8.3.143.0. Upgrading to 8.5.x would involve a lot of work as we still have older APs which are supported on 8.3.x but not 8.5.x.
01-18-2019 01:52 AM
05-17-2019 12:22 PM
02-14-2020 03:47 AM
Same phenomenon with Aironet 2800 and WLC SW 8.5.160 on Catalyst 2960X
02-16-2020 10:51 PM
Then it should be a different bug. Please open a new thread and include the error messages you see and also the configuration of the switchport plus software version of the switch.
02-17-2020 02:39 AM
Ok i will open a new thread
02-17-2020 02:54 AM
02-16-2020 11:00 PM
02-17-2020 02:44 AM
I am using 8.5.151.0 and having same issue with one 2802 AP.
02-17-2020 02:46 AM
That is not possible, the problem was temporary and has now gone and is not reproducible, i had running 40 2802I temporary for an event and the issue was only on one port of an 2960X.
The AP´s were deployed to six 2960X but the issue was on only one port of an 2960X although all switchports and all AP´s had the same identical configuration.
04-06-2020 01:17 AM
Same issue with 8.3.143.0
Any luck with this ?
04-06-2020 01:32 AM
04-06-2020 01:34 AM
8.3.143.0 was released on 05 June 2018.
The fix is found in release 8.5.151.0 which was released back in 20 June 2019.
Try upgrading the firmware of the controller.
