03-14-2018 01:40 AM - edited 07-05-2021 08:22 AM
Our switch, WS-C3750X-24P running 15.0(2)SE4, keeps Reporting Duplex mixmatch With most of Our 2800 AP's;
Mar 14 09:32:18.338: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/14 (not half duplex), with XXX_AP3 GigabitEthernet0 (half duplex).
Mar 14 09:32:21.786: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/16 (not half duplex), with XXX_AP6 GigabitEthernet0 (half duplex).
The WLC (Cisco 5508, sw 8.3.140.0) reports speed 1000 and Duplex full. The switch also reports a-full and a-1000 on the switchports. I can only assume that this is a bug somewhere..
03-14-2018 02:14 AM
04-10-2018 06:53 AM
Please check CSCvi84511
Problem appeared after upgrade from 8.5.0.110 to 8.5.0.120
09-04-2018 09:37 AM
We are seeing this on 8.3.141 (recently deferred) and 8.3.143. We are not using the AUX port as in the bug, just the POE port.
12-11-2018 08:53 AM
known bug.. and it is still not fixed in 8.5.140.0 code on a 5508 with the AP attached to a 3850 on Denali 16.3.2 code. Its seems to be putting the LAG package in to suspend mode.
08-15-2018 11:37 PM
Hello!
Is there already a solution to this emblem? Our log server is flooded with these messages.
Affected APs only AIR-2802, WLC version 8.3.140.0
08-15-2018 11:44 PM
Just try to upgrade to 8.5. 135 and check, may it will solve the issue
Rgds/Sudhir
08-16-2018 01:03 AM
09-04-2018 07:18 AM
We are seeing this problem on 8.3.141 and 8.3.143
09-24-2018 02:48 PM
I am seeing this on 8.3.143 with 3802 APs
09-24-2018 03:04 PM
09-25-2018 01:08 PM
Where have you heard that 8.3.143 is the last release in that train? https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html does not indicate that. I'm trying to plan future upgrades and if i should move to 8.5 from 8.3, that would be good to know.
09-25-2018 02:00 PM
07-29-2019 05:48 PM
We are running 5520 8.5.135 with 2802 and also have same issue/bug
07-30-2019 01:00 AM - edited 07-30-2019 01:00 AM
Upgrade to 8.3.150.0, it's fixed there:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83mr5.html
