09-26-2016 08:07 AM - edited 07-05-2021 05:53 AM
When I restart Aironet 2802i that's powered by SG300-28PP 28-Port Gigabit PoE+ switch, I see the following message:
Aironet 2800 series getting started guide mentions "Any 802.3at (25.5 W) compliant switch port", and SG300-28PP seems to be compliant.
Please advise, thanks.
Dennis
Solved! Go to Solution.
09-28-2016 07:12 AM
Oh sorry, I had a 2602 in my head but you are using the in-built WLC? I haven't had a chance to play with those but guess it will be the same.
Try show ap summary and show ap config 802.11a summary
Cheers,
Ric
09-26-2016 05:14 PM
Do you have any other PoE devices attached to the switch? Its overall power budget is 180W and should support 802.3at as you've said.
You could try setting the power statically on the switchport through this interface command:
conf t
interface gi <#>
power inline static max 25000
end
verify through show power inline:
switch#sh power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 370.0 0.0 370.0
Interface Admin Oper Power Device Class Max
(Watts)
09-27-2016 08:25 AM
I don't think the command 'power inline static max 25000' can be run. Here are the options:
switcha6ae68(config-if)#power inline
limit The port limit of the interface from the point of view
of inline power management.
never Turns off the device discovery protocol
powered-device powered device
priority The priority of the interface from the point of view
auto Turns on the device discovery protocol
Also, I've set the Priority to be 'Critical' through the web interface,
And the port shows: Administrative Power Allocation(mW) to be 30000, and Max Power Allocation (mW) AT 31500.
Power Consumption (mW) shows 10400 for this Aironet.
Just wondering if you have any suggestions on how to resolve this issue. Maybe this is a software issue on the Aironet 2808i? thanks for your help.
switcha6ae68#show power inline
Port based power-limit mode
Inrush Test: Enable
Unit Power Nominal Power Consumed Power Usage Threshold Traps Temp (C)
1 On 180 Watts 35 Watts (19%) 95 Disable 51
gi5 Auto On critical class4
09-27-2016 05:09 PM
Hmm quite odd actually. The two are negotiating the right class (4) and the switch looks capable of providing the right power so that implies the AP is perhaps not requesting the full amount or something else is causing that negotiation to fail.
Just confirming - now that you have set a few commands on the switch are you still seeing the original log on the AP "Radio1 not started, not enough POE power"?
A couple of other troubleshooting steps:
1) Force the interface up on the AP
debug capwap console cli (required if lightweight AP)
conf t
int do1
no shut
end
2) Debug PoE on the switch
debug ilpower event
debug ilpower controller
Monitor both during an AP reset
3) Replace the UTP Leads between switch and AP. If it is using structured cabling try plugging the AP directly into the switch temporarily with a new UTP lead to see if that makes a difference.
09-28-2016 06:22 AM
I think the message might be red herring actually. I am seeing this message towards the end of the boot sequence, and when the AP actually comes up, I can connect to it. Unless there are more than two radios, then they are definitely up and functioning.
09-28-2016 06:25 AM
So you can see both 2.4 and 5GHz networks? What is the current PoE draw once the AP is up? If you log into the AP and so a "sh ip int brief" you should be able to see if the dot11radio0 and dot11radio1 interfaces are up or down.
It is possible for it to run dot11radio0 (2.4GHz) but leave dot11radio1 (5GHz) off if there isn't enough power. Otherwise.. if you're happy then all good!
Ric
09-28-2016 06:36 AM
Hmm,
"sh ip int brief" is not a valid command. Any suggestions on how to check to see if the radios are up from commandline? thanks.
Dennis
09-28-2016 06:51 AM
Normally you'd see something like this:
AP1234#show ip int br
BVI1 10.15.24.128 YES DHCP up up
Dot11Radio0 unassigned NO unset up up
Dot11Radio1 unassigned NO unset up up
GigabitEthernet0 unassigned NO unset up up
If not try "show interfaces"
AP1234#show interfaces
BVI1 is up, line protocol is up
Hardware is BVI, address is ecbd.1dd2.8660 (bia ecbd.1dd2.8660)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 5000 usec,
Keepalive set (10 sec)
Last input 00:00:01, output never, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
4749478 packets output, 1266329334 bytes, 0 underruns
0 unknown protocol drops
Dot11Radio0 is up, line protocol is up
Hardware is 802.11N 2.4GHz Radio, address is ecbd.1de7.0f00 (bia ecbd.1de7.0f00)
MTU 1500 bytes, BW 54000 Kbit/sec, DLY 1000 usec,
Last input never, output 00:00:00, output hang never
Input queue: 0/42878/677/0 (size/max/drops/flushes); Total output drops: 4365830
Output queue: 0/30 (size/max)
5 minute input rate 10000 bits/sec, 6 packets/sec
334789236 packets input, 734555846 bytes, 0 no buffer
51965016 packets output, 1287641182 bytes, 0 underruns
14784 output errors, 0 collisions, 111 interface resets
0 lost carrier, 0 no carrier
Dot11Radio1 is up, line protocol is up
Hardware is 802.11AC 5GHz Radio, address is ecbd.1de7.0f00 (bia ecbd.1de7.0f00)
Input queue: 0/42878/467/0 (size/max/drops/flushes); Total output drops: 4962144
40030257 packets input, 3373335437 bytes, 0 no buffer
59325364 packets output, 1648403497 bytes, 0 underruns
12585 output errors, 0 collisions, 1241 interface rese
09-28-2016 07:04 AM
Apparently Aironet 2802i has different set of commands..
'show interface' requires a parameter, and 'show interface summary' or 'show sysinfo' doesn't mention anything about the radio.
Which controller are you using? Is it an Mobility Express controller or something else?
09-28-2016 07:12 AM
Cheers,
Ric
09-28-2016 07:19 AM
'show ap config 802.11a summary' and 'show ap config 802.11-abgn summary' shows that the radios are all enabled for both of the access points that we have in the cluster. thanks!
11-01-2017 10:27 AM
Thanks for sharing this really helped..
06-20-2018 07:03 AM
I had the same issue on a 4507 that supports PoE+. AP was showing the following on console:
Radio0 not started, not enough POE power
It was only occurring on 1 of our 3 4507 switches. The other two worked fine. I was able to resolve the issue by turning on LLDP.
08-05-2019 11:53 AM
I had same issue but another situation:
[Cisco Switch PoE 802.3af] ------ [PWRINJ6] ----[AP3802 Capwap mode]
With interface at switch side with PoE enabled: brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
So, we have to issue "power inline never" at switch 802.3af side to solve it:
brain: Power mode: Full-Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(FALSE)
Regards.
Jorge.
