Aironet 600 and Catalyst 3850
Adrian Ardelean
Hi all,
Is it possible to deploy Aironet 600 with 3850 switch? Or I really need 2500/5500/7500 WLC?
Thank you!
NO, As per below OEAP600 is not supported by 3850. So you need any other controller model(like 2504, 5508,etc) to support OEAP600 series.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12686/qa_c67-722110.html
Q. Which models of access points can a Cisco Catalyst 3850 switch support?
A. The following models of access points are supported: LAP1040, LAP1142, LAP1260, CAP3500, CAP3600, CAP2600, and CAP1600.
Rasika
***** Pls rate all useful responses *****
5 Replies 5
Saurav Lodh
Level 7
Level 7
Hello Adrian,
This office extend AP can be placed directly to a dmz/router with switch in fashion. The fire wall should allow the capwap channel between you Ap and remote WLC , follow the below deployment
http://www.cisco.com/en/US/products/ps11579/products_tech_note09186a0080b7f10e.shtml
I meant to use it with 3850 as a WLC
aqjaved
Level 3
Level 3
Please check the below link which can give your better understanding about the compatibility matrix:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Rasika
Thank you very much. It seems I have to budget one for next year
