03-07-2019 02:08 AM - edited 07-05-2021 10:00 AM
Hello
i have all acces point are same channel 36 with 5 gh band
i would to know if correcte , it ok for this all access point are same channel ? can give a problem or not ?,
please , i would some one answer me for this problem !! and i would what solution if al acces point give e problem !!
thanks in advanced
Solved! Go to Solution.
03-07-2019 03:47 AM
1. DCA must be set to automatic.
2. If APs coverage area are not overlaping then it will not be an issue if they are on same channel.
Dont forget to rate helpful posts
03-07-2019 04:16 AM
Also..enable CleanAir: it will detect and classify interferers.
EDRRM: It will allow the WLC to change channels and/or lower the power of the AP to minimize the effects of co-channel interference.
Dontf orget to rate helpful posts
03-07-2019 02:15 AM
i would to know if all 26 acces point ares same channel 36 in band 5 gh is Ok or NOT ???????????,
if that is impact the problem so what is the solution that i can do !!!
please i need a help
03-07-2019 02:16 AM
- Describe you Wifi-architecture , Standalone AP's , controller-based, Mesh , Meraki --- ? Please elaborate!
M.
03-07-2019 02:24 AM
Wifi-architecture: infstracture based a controller 3504 cisco and 26 acces point 1815i
two fortigate ( primary and backyp ) as servers DHCP and two router cisco 2921 primary and bacup to network wan
that is hardware
03-07-2019 02:28 AM
can you tell me it is normal all 26 acces point are same channel !!
what solution can you give me !!
03-07-2019 02:29 AM
- Check wether DCA Is set to automatic , should be the default (unless someone tempered with it); also check the thread below :
M.
03-07-2019 02:36 AM
it is automatic DCA and other paramter also id by default
please can you give a team view to chek controller !!
and i would to know if it is normal all acces point in band 5 gh all same channel !! so what i can check other
thanks
03-07-2019 02:44 AM
can you tell me if it is normal to have all acces point in band 5 gh all same channel 36 !! so what i can check other
thanks in advance
03-07-2019 03:47 AM
03-07-2019 03:01 AM
can you give any information to chek this sitauation and i wait to answer me now beacuse we have in Tunsia event arab
please help me to know this infastrctre is correct
thanks in advance
03-07-2019 03:19 AM
i need a help
thanks in advance
03-07-2019 04:16 AM
