10-31-2019 06:10 AM - edited 07-05-2021 11:13 AM
Hello Cisco WLAN experts,
recently I have noticed that on one of our Wism2-WLCs running 8.3.141 all WLAN APs
are configured by RRM to use Channel 1* in 802.11b-WLAN:
What might be worng ?
How can I easily start RRM all over to calculate a new deployment to use channel 1 and 6 and 11 finally ?
I have tried to start all-over using:
config 802.11b channel global restart
But it seems to me that RRM seems to remain in Startup somehow even after several hours.
(WiSM-slot22-1) >show advanced 802.11b channel
Leader Automatic Channel Assignment
Channel Assignment Mode........................ AUTO
Channel Update Interval........................ 600 seconds [startup]
Anchor time (Hour of the day).................. 0
Update Contribution
Noise........................................ Enable
Interference................................. Enable
Load......................................... Disable
Device Aware................................. Enable
CleanAir Event-driven RRM option............... Enabled
CleanAir Event-driven RRM sensitivity.......... Medium
CleanAir Event-driven RRM Rogue Contributio.... Disabled
Channel Assignment Leader...................... WISM2_193_3_KNE (10.241.230.103) (::)
Last Run....................................... 582 seconds ago
Last Run Time.................................. 0 seconds
DCA Sensitivity Level: ...................... STARTUP (5 dB)
DCA Aggressive Remaining Cycle................. 5 (50 minutes)
DCA Minimum Energy Limit....................... -95 dBm
Channel Energy Levels
Minimum...................................... -86 dBm
Average...................................... -72 dBm
Maximum...................................... 13 dBm
Channel Dwell Times
Minimum...................................... 0 days, 01 h 07 m 14 s
Average...................................... 21 days, 01 h 58 m 47 s
Maximum...................................... 293 days, 20 h 39 m 35 s
802.11b Auto-RF Allowed Channel List........... 1,6,11
Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10,12,13
The WLC is the RRM-Leader for 802.11b but does not show any Current AP number:
(WiSM-slot22-1) >show advanced 802.11b group
802.11b Radio RF Grouping
RF Group Name.................................. ukw1
RF Protocol Version(MIN)....................... 101(30)
RF Packet Header Version....................... 2
Group Role(Mode)............................... LEADER(AUTO)
Group State.................................... Idle
Group Update Interval.......................... 600 seconds
Group Leader................................... WISM2_193_3_KNE (10.241.230.103) (::)
Group Member
Maximum/Current number of Group Member......... 20/1
Maximum/Current number of AP................... 2000/0
Last Run....................................... 108 seconds ago
(WiSM-slot22-1) >show advanced 802.11b monitor
Default 802.11b AP monitoring
802.11b Monitor Mode........................... enable
802.11b Monitor Channels....................... DCA channels
802.11b RRM Neighbor Discovery Type............ Transparent
802.11b RRM Neighbor RSSI Normalization........ Enabled
802.11b AP Coverage Interval................... 90 seconds
802.11b AP Load Interval....................... 60 seconds
802.11b AP Monitor Measurement Interval........ 180 seconds
802.11b AP Neighbor Timeout Factor............. 20
802.11b AP Report Measurement Interval......... 180 seconds
(WiSM-slot22-1) >show advanced 802.11b summary
Leader RRM Information
Member RRM Information
AP Name MAC Address Admin Oper Channel TxPower
ZIM-AP418 00:25:84:24:57:70 ENABLED UP 1* *1/7 (17 dBm)
KFR-AP34 1c:6a:7a:b5:9c:d0 ENABLED UP 1* *1/6 (16 dBm)
ZIM-AP228 00:25:84:24:eb:e0 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP324 00:25:84:24:bb:80 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP256 00:25:84:24:bf:20 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP368 00:25:84:24:53:c0 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP410 00:25:84:24:55:80 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP260 a4:56:30:8e:f5:b0 ENABLED UP 1* *2/7 (14 dBm)
ZIM-AP289 cc:d5:39:64:f2:20 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP404 00:25:84:24:53:f0 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP315 cc:d5:39:65:79:80 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP443 00:25:84:24:e9:70 ENABLED UP 1* *1/7 (17 dBm)
ZIM-AP304 00:25:84:24:b8:90 ENABLED UP 1* *1/7 (17 dBm
What is wrong here ?
Thank You for any help in advance
Greetings from Frankonia
Wini
10-31-2019 06:17 AM
if you see star on channel number means its a global assignment.
Now come to your quetsion reagrding having the same channel:
1. DCA must be set to automatic.
2. If APs coverage area are not overlaping then it will not be an issue if they are on same channel.
Dont forget to arte helpful posts
10-31-2019 02:09 PM
11-07-2019 06:51 AM
I can tell that the Situation has been improved now.
We found out that the Wism2-High-Availability was broken between the two modules in a VSS.
One of the modules was found in factory-default, while the secondary WisM2 had taken over all APs
and calculated them all in channel 1.
On this unit, also a Memory Problem was visible, which disappeared after a reload and new Setup
after recovery of the broken WiSM2 and reactivating of the SSO-Setup.
Sorry about all this old Hardware and Software. But we still are running on 1142 WLAN APs partly.
New 9800 are already in place, but I have no clue how to configure all this new DNA-stuff.
I think it is time for retirement before diving into this new intention-based world of Cisco.
Kind regards
Wini
