1719
AP 1142N low power
hi
i connected a new Cisco 1142n access points to a cisco 3560E 24 port POE switch. the AP is getting only lower power which is 14.5 but the switch is capable of deleivering 15.4 watts. i checked the console messages in the AP and it is giving the error message
CDP_PD-2-POWER_LOW: All radios disabled
there is an other same model AP connected to the switch and it is getting full power
please let me know asap because i am in middle of a project
Karthik
Everyone's tags (1)
7 REPLIES 7
AP 1142N low power
In the AP config, you can go in and tell it that it's getting pre-standard power.  Optionally, you can disable CDP on that port as well.
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
AP 1142N low power
are you asking me to login to AP and set a prestandard power
please explain me how to do it
AP 1142N low power
for an IOS AP,
conf t
config power inline negotiation prestandard source
If this is a WLC installation, it's in the AP config
HTH,
Steve
AP 1142N low power
but in the switch if i type in the command show power inline i see this AP drawing only 14.5 watts..there is another AP connected to this switch which is drawing enough power 15.4 watts
Re: AP 1142N low power
that can happen. Depends in how much power the switch tells the AP is available during the CDP/FLP negotiation
AP 1142N low power
hi
can you let me know how to make the controller upgrade the image of a new Cisco AP connected.
Hall of Fame Community Legend
AP 1142N low power
On the Cisco switch, please post the output to the command "sh power inline".
Content for Community-Ad
August's Community Spotlight Awards
