Highlighted
Beginner
AP 1252 can't connecting to Virtual WLC
Dears ,
i need a help to solve this problem , i have AP 1252 , it was standalone mode , i convert it to LAP i got the IOS from cisco site , i am using virtual WLC , when i connect AP to WLC (10.10.65.100 ) , i got ip address from DHCP , and here  are the error messages that appear :
error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
 %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255
%CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.65.100 peer_port: 5246
 DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:94 First fragment for seq 2 is missing
%CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.10.65.100 peer_port: 5246
 %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.65.100
%DTLS-5-ALERT: Received WARNING : Close notify alert from 10.10.65.100
%DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.65.100:5246
bsnInitRcbSlot: slot 1 has NO radio
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
%LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
%LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
%LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
best regards
Everyone's tags (1)
VIP Advocate
Re: AP 1252 can't connecting to Virtual WLC
Hi @alalem2010
 Which is the WLC version?  Keep in mind that this AP can´t not join WLC newer then 8.0.252.0.
-If I helped you somehow, please, rate it as useful.-
Beginner
WLC version may not support EOL AP's if it does do a "debug capwap events enable" and have look what information it is showing. But my bet is the firmware version does not support the AP
Beginner
is it not compatible ?
Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.152.0
RTOS Version..................................... 8.0.152.0
Bootloader Version............................... 8.3.15.96
Emergency Image Version.......................... 8.0.152.0
Build Type....................................... DATA + WPS
Hall of Fame Guru
Please post the complete output to the following commands:
1.  vWLC:  sh sysinfo;
2.  vWLC:  sh time;
3.  AP:  sh version; and
4.  AP:  sh ip interface brief
Beginner
thank you for fast replay, here are the info that you requested :
System Name...................................... Cisco_ba:76:e3
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 10.10.65.100
IPv6 Address..................................... ::
System Up Time................................... 1 days 17 hrs 57 mins 17 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:50:56:BA:76:E3
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
 (Cisco Controller) >show time
Time............................................. Wed Feb 14 09:49:38 2018
Timezone delta................................... 0:0
APc47d.4f88.cc60>sh version
cisco AIR-LAP1252G-E-K9 (PowerPC 8349) processor (revision C0) with 52214K/13312K bytes of memory.
Processor board ID FCZ1352P05V
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
LWAPP image version 8.0.152.0
1 Gigabit Ethernet interface
1 802.11 Radio
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C4:7D:4F:88:CC:60
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC13474FLM
Top Assembly Part Number             : 800-29533-03
Top Assembly Serial Number           : FCZ1352P05V
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1252G-E-K9
APc47d.4f88.cc60>sh ip inter brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.10.65.19    YES DHCP   up                    up
Dot11Radio0                unassigned      NO  unset  up                    up
GigabitEthernet0           unassigned      NO  unset  up                    up
Hall of Fame Guru
The vWLC is configured for the US.
The AP has a Regulatory Domain of "-E" (for Europe).  And finally, ...
There is a very big chance the vWLC has an incorrect time.  Kindly configure NTP.  If the time and date is wrong, the AP won't join.
Beginner
i am sure the AP time and vWLC are the same time , have i choose another Regulatory Domain else US ?
Hall of Fame Guru
Turn off US and enable, say, Germany.
Beginner
finally it have joined , i just change (Regulatory Domain) , thank you for help
Ask the Expert- Firepower configuration & troubleshooting
