AP 1852e sudden restarting
networkGuy69
Hi all,
I have issue with AP1852e, runs Mobility Express mode. Could you please help me ?
Model: AIR-AP1852E-S-K9
OS version: 8.5.120.0
However, it's restarted frequently 1 time/1 day. I show log and it shows that as below:
*Dot1x_NW_MsgTask_0: Feb 14 09:09:38.186: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 84:41:67:40:77:2a may be using an incorrect PSK
*ConfigSync: Feb 14 09:06:18.296: %CONFIGSYNC-3-CONFIG_SYNC_SEM_REL_FAIL: spam_api.c:73799 Cfgsync sem relase failed Unable to relase the sem LOCK
*Dot1x_NW_MsgTask_0: Feb 14 09:02:47.205: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 2c:a9:f0:94:99:b7 may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:55:54.556: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 2c:a9:f0:94:99:b7 may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:38:32.728: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 84:41:67:40:77:2a may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:34:55.498: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 84:41:67:40:77:2a may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:30:58.614: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 2c:a9:f0:94:99:b7 may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:30:11.994: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 84:41:67:40:77:2a may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:29:44.023: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client d0:53:49:3f:77:32 may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:24:55.042: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client c0:2e:25:eb:f0:99 may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:24:54.447: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 84:41:67:40:77:2a may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:24:50.379: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:452 Invalid replay counter from client c0:2e:25:eb:f0:99 - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*Dot1x_NW_MsgTask_0: Feb 14 08:21:09.477: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client 20:ab:37:68:98:7f may be using an incorrect PSK
*Dot1x_NW_MsgTask_0: Feb 14 08:09:23.312: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:729 Client b8:c1:11:61:0d:7b may be using an incorrect PSK
*spamApTask0: Feb 14 08:08:28.621: %CAPWAP-3-MDNS_INIT_NOT_DONE: capwap_ac_sm.c:8433 mDNS module is not initialized yet, but a mDNS AP : 70:0b:4f:59:7e:00 has joined.Aggregated query is not sent until mDNS init.
*spamApTask0: Feb 14 08:08:28.601: %CAPWAP-3-AP_AUTOCONVERT_ERR: capwap_ac_sm.c:3714 The system is unable to autoconvert AP 70:0b:4f:59:7e:00 to supported mode.
*fp_main_task: Feb 14 08:08:25.990: %CLIWEB-3-INIT_FAILED: cli_web_util.c:780 Unable to initialize. Reason: Unable to set the https support to dtl..
*fp_main_task: Feb 14 08:08:25.987: %CLIWEB-3-INIT_FAILED: cli_web_util.c:761 Unable to initialize. Reason: Unable to set the secure webauth mode to dtl..
*sntpReceiveTask: Feb 13 17:22:37.236: %DNS-3-GETADDRINFO_SUCCESS: dns_query.c:251 getaddrinfo succeeded
*ethoipSocketTask: Feb 13 17:22:31.913: %ETHOIP-2-SOCKET_OPEN_ERROR: ethoip.c:205 Unable to open Ethernet-over-IP socket
*capwapPingSocketTask: Feb 13 17:22:30.421: %CAPWAPPING-2-SOCKET_OPEN_ERROR: capwapping_shim_wlc.c:712 Unable to open Mobility Data Ping socket
*mmListen: Feb 13 17:22:27.034: %MM-3-SOCK_OPER_FAILED: mm_listen.c:12398 Failed to set socket option IP_MULTICAST_TTL with errno=9.
*mmListen: Feb 13 17:22:27.034: %MM-3-SOCK_OPER_FAILED: mm_listen.c:12390 Failed to set socket option IPV6_MULTICAST_HOPS with errno=9.
--More-- or (q)uit
*mmListen: Feb 13 17:22:27.034: %MM-3-SOCK_OPER_FAILED: mm_listen.c:12973 Failed to set socket option IPV6_TCLASS with errno=92.
*fp_main_task: Feb 13 17:22:24.571: %CNFGR-3-INV_COMP_ID: cnfgr.c:3881 Invalid Component Id : Unrecognized (45) in cfgConfiguratorInit.
*spamSocketTask: Feb 13 17:22:24.542: %LWAPP-2-SOCK_ERR: spam_net.c:2230 Error opening LWAPP socket
Leo Laohoo
Well, the AP is running 8.5MR2. That is not a good version to stay on.
Leo Laohoo
thank for your comment, which is good version for that ?
Try 8.5.151.0.
