Highlighted
Beginner
AP(3802I) not able to join WLC 5520 with 8.2 software version
Hi ,
I am try for AP to join controller.Its not passing the join phase.
 AP is brand new AP (3802I) and controller is 5520 software version is 8.2
I am seeing discovery response sent after that its throwing below error
*spamApTask5: Nov 18 13:56:59.142: apType: Ox34 bundleApImageVer:
*spamApTask5: Nov 18 13:56:59.142: Could not find image version of bundled AP(apType: 52)!!!
*spamApTask5: Nov 18 13:56:59.142: Unable to get AP Bundled Version. Using Controller Version!!!
How to fix the issue??
10 REPLIES 10
Highlighted
VIP Mentor
paste the output of these commands:
sh sysinfo from WLC (Specially country code and correct SW version on WLC)
sh version form AP
Also paste the complete boot-up process from cisco AP console.
*** IF AP is having mesh image then you need to add mac address of AP in AP policies of WLC.
Dont forget to rate helpful posts
Highlighted
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.130.0
RTOS Version..................................... 8.2.130.0
Bootloader Version............................... 8.1.102.0
Emergency Image Version.......................... 8.1.102.0
Build Type....................................... DATA + WPS
System Name...................................... WLC1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2170
Redundancy Mode.................................. Disabled
IP Address....................................... x.x.x.x
IPv6 Address..................................... ::
System Up Time................................... 2 days 23 hrs 14 mins 43 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... GB  - United Kingdom
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 0
Burned-in MAC Address............................ x.x.x.x.x.
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 1500
System Nas-Id.................................... x.x.x.x.
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
Unfortunately, I don't have remote access to AP.
what is the expected reason for this error??? as am basically very new to wireless
Highlighted
we need to check the access point console.
Did you try to add the amc address of AP in cisco wlc ??
Highlighted
If you are referring to add AP mac address in AP Authorization List of AP polices in WLC, then yes, I tried doing it.
But no luck. still AP stuck in join state
Highlighted
try to get access to AP console and provide the complete logs.
Highlighted
Can you get the output of "debug capwap error enable" from the WLC CLI ?
and also share the MAC address of the AP in question ?
Manish
Highlighted
Dear Sandeep
Thanks a lot for reply
Here are the details,licence ,country code all set
Highlighted
Hi Vijay,
2 points:
1. Your AP is an 1852 . The first image that supports this AP is 8.1.111.0. You should upgrade your WLC to at least 8.2 image.
2. The AP is "E" regulatory domain but the country code that you have selected in the WLC is Kuwait. Assuming that your WLC is in Kuwait , you ideally need to get an AP with regulatory domain "I" or enable any European country in your WLC. The first option is recommended technically and legally.
Cheers,
Manish
Highlighted
Hai
Thanks for the update,issue solved as i upgrade controller to version 8.2.166
Highlighted
Beginner
I had the same issue. This could be one of the following:
1) Licenses not applied to the WLC: ManagementSoftware ActivationLicenses
2) AP MAC restriction list: SecurityAP PoliciesPolicy ConfigurationAuthorize MIC APs against auth-list or AAA
and below
Security > AP Policies > AP Authorization List > Remove any restrictions
3) Potential bug: https://quickview.cloudapps.cisco.com/quickview/bug/CSCuy50490
Content for Community-Ad
