07-17-2019 12:30 PM - edited 07-02-2021 07:10 PM
SW configuration-
ip dhcp pool AP_Pool
network 172.16.64.0 255.255.255.0
default-router 172.16.64.1
option 43 hex f104.ac10.2068
dns-server 172.16.32.40
interface Vlan64
description AP_Mgmt
ip address 172.16.64.1 255.255.255.0
Logs on AP
*Mar 1 00:00:16.231: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:17.622: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:17.628: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:17.748: loading Power Tables from ram:/Z2.bin. Class = A
*Mar 1 00:00:17.748: record size of 2ss: 404 read_ptr: 274D1B8
*Mar 1 00:00:20.953: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:21.000: loading Power Tables from ram:/Z5.bin. Class = N
*Mar 1 00:00:21.000: record size of 2ss: 404 read_ptr: 274D1B8
*Mar 1 00:00:21.026: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:21.029: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Jul 14 10:15:16.091: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 15.3(3)JD16, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 05-Jun-18 01:49 by prod_rel_team
*Jul 14 10:15:16.091: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Jul 14 10:15:16.220: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Jul 14 10:15:16.223: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Jul 14 10:15:16.226: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Jul 14 10:15:16.226: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Jul 14 10:15:16.251: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Jul 14 10:15:16.254: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul 14 10:15:16.257: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Jul 14 10:15:17.157: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Jul 14 10:15:25.276: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.64.139, mask 255.255.255.0, hostname AP44d3.ca59.7b25
*Jul 14 10:15:33.600: Currently running a Release Image
validate_sha2_block: Failed to get certificate chain
*Jul 14 10:15:33.622: Using SHA-1 signed certificate for image signing validation.%Default route without gateway, if not a point-to-point interface, may impact performance
*Jul 14 10:15:39.325: AP image integrity check PASSED
*Jul 14 10:15:39.379: Non-recovery image. PNP Not required.
*Jul 14 10:15:39.394: validate_sha2_block:No SHA2 Block present on this AP.
*Jul 14 10:15:39.426: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jul 14 10:15:39.426: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
*Jul 14 10:15:49.451: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Jul 14 10:15:50.452: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 started - CLI initiated%No matching route to delete
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (172.16.32.40)
*Jul 14 10:16:00.468: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.32.104 obtained through DHCP
*Jul 14 10:16:08.146: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Jul 14 10:16:08.146: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface reset
*Jul 14 10:16:08.146: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Jul 14 10:16:09.238: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul 14 10:16:10.238: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jul 14 10:16:10.333: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul 14 10:16:11.333: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jul 14 10:17:08.528: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
Not in Bound state.
*Jul 14 10:17:13.986: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Jul 14 10:17:24.182: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.64.140, mask 255.255.255.0, hostname AP44d3.ca59.7b25
*Jul 14 10:17:34.987: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.32.104 obtained through DHCP
Not in Bound state.
*Jul 14 10:18:28.502: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Jul 14 10:18:38.694: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.64.141, mask 255.255.255.0, hostname AP44d3.ca59.7b25
Logs on WLC:
Nothing I am getting expect these logs after enabling both packet and event debug -
(Cisco Controller) >*osapiBsnTimer: Jul 18 00:50:28.129: Same gateway prevails
*osapiBsnTimer: Jul 18 00:50:38.305: Same gateway prevails
*osapiBsnTimer: Jul 18 00:50:48.545: Same gateway prevails
*osapiBsnTimer: Jul 18 00:50:58.771: Same gateway prevails
*osapiBsnTimer: Jul 18 00:51:09.021: Same gateway prevails
*osapiBsnTimer: Jul 18 00:51:19.131: Same gateway prevails
*osapiBsnTimer: Jul 18 00:51:29.397: Same gateway prevails
*osapiBsnTimer: Jul 18 00:51:39.555: Same gateway prevails
*osapiBsnTimer: Jul 18 00:51:49.769: Same gateway prevails
*osapiBsnTimer: Jul 18 00:51:59.943: Same gateway prevails
Solved! Go to Solution.
07-20-2019 04:03 AM
07-17-2019 09:46 PM
Any Clue?? need expert advice please
07-17-2019 10:31 PM
can you Ping 172.16.32.104 from vlan 64?
07-17-2019 11:47 PM
yes, I can
SW1#ping 172.16.32.104 source vlan 64
Sending 5, 100-byte ICMP Echos to 172.16.32.104, timeout is 2 seconds:
Packet sent with a source address of 172.16.64.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
SW1#
07-17-2019 11:49 PM
But I am not able to ping WLC from AP and vice versa.
07-18-2019 12:10 AM
DHCP Option 43 is either not configured or configured incorrectly.
What happens if the command is entered on the AP: capwap ap primary-base <WLC name> <WLC ip address>
07-18-2019 12:23 AM
neither of them work I have tried all option.
Regarding the DHCP option 43 ..it is correctly defined under the pool for Vlan 64 as shared in the configuration
07-18-2019 12:33 AM
07-18-2019 01:13 AM
There is no any firewall in between the welcome and AP
07-18-2019 01:20 AM
07-18-2019 09:37 AM
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.170.0
RTOS Version..................................... 8.2.170.0
Bootloader Version............................... 8.3.15.96
Emergency Image Version.......................... 8.3.143.0
Build Type....................................... DATA + WPS
System Name...................................... WLC1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 172.16.32.104
IPv6 Address..................................... ::
System Up Time................................... 0 days 1 hrs 21 mins 39 secs
System Timezone Location......................... (GMT +5:30) Colombo, New Delhi, Chennai, Kolkata
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... IN - India
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 50:00:00:01:00:01
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
(Cisco Controller) >show time
Time............................................. Thu Jul 18 22:04:49 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT +5:30) Colombo, New Delhi, Chennai, Kolkata
NTP Servers
NTP Polling Interval......................... 3600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 1 172.16.32.1 Not Synched AUTH SUCCESS
(Cisco Controller) >show interface
Incorrect usage. Use the '?' or <TAB> key to list commands.
(Cisco Controller) >show interface summary
Number of Interfaces.......................... 3
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
management 1 32 172.16.32.104 Static Yes N/A
service-port N/A N/A 192.168.10.104 Static No N/A
virtual N/A N/A 1.1.1.1 Static No N/A
AP44d3.ca59.7b25#show ver
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 15.3(3)JC15, RELEASE SOFTWARE (fc1)
Compiled Thu 07-Jun-18 16:12 by prod_rel_team
ROM: Bootstrap program is C3500 boot loader
BOOTLDR: C3500 Boot Loader (AP3G1-BOOT-M), Version 15.3 [vtoky-imagetype 106]
AP44d3.ca59.7b25 uptime is 15 minutes
System image file is "flash:/ap3g1-k9w8-mx.153-3.JC15/ap3g1-k9w8-xx.153-3.JC15"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3502I-N-K9 (PowerPC460exr) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FGL1530S3D4
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 8.2.170.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 44:D3:CA:59:7B:25
Part Number : 73-12175-05
PCB Serial Number : FOC15292ASA
Top Assembly Part Number : 800-32891-01
Top Assembly Serial Number : FGL1530S3D4
Top Revision Number : A0
Product/Model Number : AIR-CAP3502I-N-K9
Configuration register is 0xF
07-18-2019 10:19 AM
Hi again @CSCO11844255
I'm not tottale sure but I did a quick look for your AP and your country code domain -N and I can't find your model of AP and the regulatory domain, not sure if your APs in local site are -N too. Try this... Add a new country code, you can try whit USA or MX and check whats going on.
If you want to do by yourself the serch I leave the link right here
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
07-18-2019 10:36 AM
07-18-2019 11:48 AM
sorry heard that. About your question the answer is not, you don't need to have a interface with vlan 64, just need to be reachable. I have similar deployment and I use DHCP 43. So, just try this.. add a ip helper address in your vlan 64 with the WLC ip address and check.
I did in my network check this out
07-19-2019 08:28 AM
