515
Beginner
ap cannot join to controller
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Nov 21 17:00:38.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.77.95:5246
*Nov 21 17:00:38.999: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface is getting down
*Nov 21 17:00:38.999: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface is getting down
*Nov 21 17:00:39.071: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Nov 21 17:00:39.071: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Nov 21 17:00:39.091: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Nov 21 17:00:39.091: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Nov 21 17:00:39.091: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Nov 21 17:00:39.095: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 21 17:00:40.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 21 17:00:40.123: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Nov 21 17:00:40.131: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 21 17:00:41.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 21 17:00:41.123: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov 21 17:00:41.151: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 21 17:00:41.159: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov 21 17:00:41.167: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 21 17:00:42.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 21 17:00:42.159: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov 21 17:00:42.187: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 21 17:00:43.187: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 21 17:00:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.77.95 peer_port: 5246
*Nov 21 17:00:49.239: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.10.77.95 peer_port: 5246
*Nov 21 17:00:49.239: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.77.95
i have already check country code, add mac ap in certification mic in ap policies. the clock already corret but ap still can't join to controller. please help. thank you
Everyone's tags (1)
6 REPLIES 6
Collaborator
Re: ap cannot join to controller
What is the model of Ap and what is the software version on the controller?
John
**Please rate posts you find helpful**
Beginner
ap model is : AIR-CAP3602I-C-K9
version 15.3(3)JD16
Highlighted
Hall of Fame Community Legend
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. AP: sh version;
4. AP: sh ip interface brief; and
5. Console into the AP and reboot. Post the entire boot-up process.
Beginner
This is output of the following command.
Kevin
Kindly configure the WLC for NTP.
Beginner
solved
Thank you
Content for Community-Ad
August's Community Spotlight Awards
