AP connects and then disconnects.
ammahend
HI Memebers,
I have a virtual controller and the AP keeps connecting and disconneting .
Number of Traps since last reset   81
Number of Traps since log last viewed   32
LogSystem TimeTrap
0Tue Nov 20 19:13:00 2012AP Disassociated. Base Radio MAC:00:1d:a1:ee:f5:a6
1Tue Nov 20 19:12:56 2012AP Disassociated. Base Radio MAC:00:1d:a1:ef:0f:d2
2Tue Nov 20 19:11:23 2012AP Disassociated. Base Radio MAC:00:1d:a1:ee:f5:a6
3Tue Nov 20 19:11:19 2012AP Disassociated. Base Radio MAC:00:1d:a1:ef:0f:d2
4Tue Nov 20 19:09:46 2012AP Disassociated. Base Radio MAC:00:1d:a1:ee:f5:a6
5Tue Nov 20 19:09:42 2012AP Disassociated. Base Radio MAC:00:1d:a1:ef:0f:d2
6Tue Nov 20 19:08:09 2012AP Disassociated. Base Radio MAC:00:1d:a1:ee:f5:a6
7Tue Nov 20 19:08:05 2012AP Disassociated. Base Radio MAC:00:1d:a1:ef:0f:d2
8Tue Nov 20 19:06:31 2012AP Disassociated. Base Radio MAC:00:1d:a1:ee:f5:a6
I have captured the logs from
debug capwap event enable
debug capwap error enable
let me know if you can guys can help me here solve this issue , if you need more outputs feel free to let me know.
kindly consider this an urgent issue.
I will appreciate any help.
Ambuj
-hope this helps-
9 Replies 9
Leo Laohoo
Need more info than this.
When the WAP disconnects, does it loose power or just disconnects from the vWLC?
no the AP is on a POE switch and is always powered on .
-hope this helps-
If you look at the WAP details after it disconnects, what does the UP time and WLC Association time like?  Please provide screenshot.
What's a wap?
You busting out on one of Leo's old post George:) haha
-Scott
Saravanan Lakshmanan
Looks like your AP is on dynamic vlan interface of wlc.
soln: on WLC, remove that dyn int where AP is on or move the AP to vlan that is not part of dyn vlan int of wlc.
there is only one WLAN called DATA , mapped to dynamic interface DATA which is in vlan 2.
-hope this helps-
how AP is connecting/reaching WLC's management interface?
AP trying to reach the management int of wlc through port-1 that is mapped to vlan 2.
what's the AP vlan?
it seem AP vlan is vlan 2, which is also an dynamic interface of wlc. either move the AP to L3 vlan that is not vlan 2 or put the ap on management vlan of wlc to fix this issue. (Note: AP can't be on dyn interface of wlc per cisco. you can still have this option that is not supported by tac just by enabling mgmt via dyn interface, and also it is not guranteed that it works stable)
*spamApTask0: Nov 20 19:01:40.091: 00:1d:a1:ee:f5:a6 Discovery Request received on wrong VLAN '2' on interface '1', management VLAN = '0' - in L3 mode, dropping the packet
