AP doesn't join controller
hcombee
I've got 4 AP's out of 7 that didn't join the controller. They get an IP address and should use option 43 to join as the other ones. show cdp neighbors learned me that they run a recovery image (AP3G2-RCVK9W8-M) but I am unable to log in using Cisco/Cisco. RTFM didn't help me, how to fix this?
hcombee
Problem solved, it seems that the configuration of the DHCP scope between two Windows DHCP servers wasn't properly synchronized. The failover server didn't had the router option, so the AP's in the second half of the scope didn't get to the controller. One of the disadvantages of function separation.
Scott Fella
You can’t ssh into the ap, you can console into the device and look at the output. If these ap’s are local, put them on the same subnet as the wlc management and see if they join. Once the ap joins, then after the ap gets the new image, you can change the vlan to whatever you want.
-Scott
Leo Laohoo
Post the output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. AP: sh version; and
4. AP: sh ip interface brief
The time is NTP Synced. I triple checked al DHCP scope settings, routing. What puzzles me is I can ping the 3 Ap's that have joined the controller but the 4 that didn't join I can only ping from their default gateway though they are in the same subnet as the other 3.  Problem is they are 100 miles from my current location and the controller is in a remote datacenter.
>show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Build Info....................................... Engineering Special
Product Version.................................. 8.5.140.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name......................................
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address.......................................
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 331 days 15 hrs 27 mins 11 secs
--More-- or (q)uit
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... NL - Netherlands
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +39 C
External Temperature............................. +20 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 29
OUI Classification Failure Count................. 804419
Memory Current Usage............................. 56
Memory Average Usage............................. 56
CPU Current Usage................................ 0
CPU Average Usage................................ 1
--More-- or (q)uit
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................ E0:2F:6D:7C:36:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
(ghg3000-nw01-InkpTpb) >show time
Time............................................. Fri Mar 27 10:36:09 2020
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 3600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 x.x.x.x In Sync AUTH DISABLED
2 0 x.x.x.x Not Tried AUTH DISABLED
hcombee
