11-15-2017 01:18 PM - edited 07-05-2021 07:52 AM
Hi Folks,
I have a problem with an AP that is not joining to the WLC. It said problems with the country code but the ap is UX mode.
AP Model: AIR-AP3702I-UXK9
WLC Configured country Codes: VE (Where i am now)
Attached:
AP:
Boot ap process.
Sh version
WLC:
debug capwap events enable
sh ap join stats
sh sysinfo
sh time:
Time............................................. Wed Nov 15 21:19:05 2017
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval......................... 604800
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 10.243.80.1 In Sync AUTH DISABLED
I really appreciate any help please.
Thanks.
Solved! Go to Solution.
11-15-2017 11:37 PM
Please check whether this doc helps
Dont forget to rate helpful posts
11-16-2017 05:20 AM
do :
clear capwap private-config
and reload AP. Once it join then foloow the above doc,
11-15-2017 11:37 PM
11-16-2017 04:09 AM
Hello, i know it but the AP is not joining to the WLC. To do it the AP must be on the WLC already.
11-16-2017 05:20 AM
do :
03-27-2018 02:42 PM
it worked for me ... thanks man !!
10-08-2018 08:47 AM
