92
Beginner
AP segregation"
In an environment with WLC, 2 SSID ("a" and "b") and tens of AP, can I have a group of AP that propagates only SSID "a" and another group that propagates both "a" and "b"?
I refer, for example in a production area, where it is necessary only "production" SSID, while in office Area is also required (or only) SSID "offices".
Where can I find help documentation?
C.
4 REPLIES 4
Enthusiast
Yes you can use AP groups to define what SSIDs will be on which APs
Here is the link  http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/configuration-guide/b_cg75/b_cg75_chapter_01011011.html
I hope this helps
Don't forget to rate this post ,if you find it helpful
VIP Mentor
Yes, configuring AP group is
Yes, configuring AP group is the way to achieve what you want.
Rasika
Refer link : http://www.cisco
VIP Mentor
By using AP groups , you can achieve this:
Here is the configuration guide guide:
https://rscciew.wordpress.com/2014/01/22/configure-ap-groups-on-wlc/
https://mrncciew.com/2013/05/30/configuring-ap-groups/
Dont forget to rate helpful posts
Content for Community-Ad
August's Community Spotlight Awards
