06-16-2019 11:42 AM - edited 07-05-2021 10:34 AM
I know that an AP i going always to see a client better. According to Jerome Harry is about 6dBm difference. I have taken the reading from the controller and I struggle to make out what is what, since the values are the other way round. The client see the ap better or I get that wrong. Can you please help me to interpretate the show client details what is,
1. Radio signal strenght indicator
2. Nearby Ap statistics
3. Scan report
--More-- or (q)uit
Number of RA Packets Dropped............... 0
Number of Policy Errors.................... 0
Radio Signal Strength Indicator............ -66 dBm
Signal to Noise Ratio...................... 33 dB
Client RBACL Statistics:
Number of RBACL Allowed Packets............ 0
Number of RBACL Denied Packets............. 0
Client Rate Limiting Statistics:
Number of Data Packets Received............ 0
Number of Data Rx Packets Dropped.......... 0
Number of Data Bytes Received.............. 0
Number of Data Rx Bytes Dropped............ 0
Number of Realtime Packets Received........ 0
Number of Realtime Rx Packets Dropped...... 0
Number of Realtime Bytes Received.......... 0
Number of Realtime Rx Bytes Dropped........ 0
Number of Data Packets Sent................ 0
Number of Data Tx Packets Dropped.......... 0
Number of Data Bytes Sent.................. 0
Number of Data Tx Bytes Dropped............ 0
Number of Realtime Packets Sent............ 0
Number of Realtime Tx Packets Dropped...... 0
Number of Realtime Bytes Sent.............. 0
--More-- or (q)uit
Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
bkom-atealab-ap01(slot 0)
antenna0: 9 secs ago..................... -64 dBm
antenna1: 9 secs ago..................... -63 dBm
bkom-atealab-ap01(slot 1)
antenna0: 248 secs ago................... -64 dBm
antenna1: 248 secs ago................... -75 dBm
atealab-test1(slot 1)
antenna0: 72 secs ago.................... -70 dBm
antenna1: 72 secs ago.................... -74 dBm
atealab-test2(slot 1)
antenna0: 248 secs ago................... -89 dBm
antenna1: 248 secs ago................... -96 dBm
Scan Report:
BSSID:......................................... f4:cf:e2:40:7f:ff
RSSI:...................................... -68 dBm
ChannelNumber:............................. 36
thank you
Solved! Go to Solution.
06-16-2019 01:27 PM
First look at the TX power your AP is using and try to find the TX power of the device you are using. Also, if the 11k info is being sent by the client, you can see both what the AP hears the client and what the client hears the AP. You can also use utilities so see what the client hears the AP, refresh rate depends on the driver versions. Then you can compare the data you are collecting to better understand this and your environment.
06-16-2019 11:20 PM
Hei Scott,
Thanks for info. I am using -11dBm in UNII-1 so I should not be any mismatch. But I am facing a new project with location and I wonder how I can site survey for that siden there is a requirement that a client should be at -75dBm seen from the pespective of APs.
So I was thinking I could take the reading from the client vs AP and use that difference as reference. According to Jerrome Herry a client is supposed to see an AP 6dBm worse but I do not see that happen in my case. Maybe that happens when Ap is set to max TX. Do you have any tips to lacation based site survey and how I should approach that ?
06-16-2019 01:27 PM
06-16-2019 11:20 PM
Hei Scott,
06-17-2019 09:45 AM
06-18-2019 01:19 AM - edited 06-18-2019 01:33 AM
Thanks Scott a lot for all the answers :)
I have only last one :)
Can you help me please understand the output from controller I had in my first post and tell me from which perspective those RSSI values are seen
3. Scan report
