07-19-2016 07:38 AM - edited 07-05-2021 05:27 AM
I need to move from AP from WLCA to WLCB, I have try
#clear capwap private-config
#delete flash:private-multiple-fs
manually configure the new WLCB to the AP
clear all config
but none are working, it keep coming back to WLCA. I saw the log and notice that the AP just don't get to discovery mood. I have Opt 43 configured for the site to point to WLCB
Hakim
07-19-2016 02:12 PM
Hi Hakim,
Try the below command & reload the AP. Refer the given post for more detail. Make sure your AP can reach WLCB (if any firewall in between, UDP 5246,5247 to be open)
erase /all nvram:
https://mrncciew.com/2013/03/17/ap-registration/
Rasika
*** Pls rate all useful responses ***
07-19-2016 07:22 PM
thank you Rasika. I will try that after working hour today and update the result.
there's no firewall between AP and WLCB, it's on the same LAN segment (same broadcast domain)
Hakim
07-20-2016 08:31 PM
Dod you move the ap high availability to wlcb and see if that works?
07-20-2016 08:39 PM
yes, that was the 1st thing I did, manually move it to WLCB IP and Name
07-20-2016 08:55 PM
Ok, are you 100% the name and IP matched exactly ? I know its basics, but Ive seen times where they are off because of a type o and it doesnt work.
07-20-2016 11:39 PM
Hi George, thank you for you suggestion, I think somehow it help. I try with upper case this time because the system name is in upper case. it works ! thanks !
07-21-2016 07:55 AM
Crazy right ? Ive had this issue more than once and they need to be exact. Im glad you got it resolved and thanks for the stars!
07-20-2016 09:10 AM
still the same.
I notice from the log it did not goes into the discovery mood, it immediately ask to connect to WLCA
*Jul 20 16:06:53.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: [WLCA IP] peer_port: 5246
I did
#erase /all nvram:
07-20-2016 02:45 PM
Try below on AP CLI
capwap ap primary-base <WLCB_name> <WLCB_mgt_IP>
Rasika
07-20-2016 05:37 PM
07-20-2016 07:09 PM
Can you confirm that there is no AP policy on WLCB preventing that AP register to it.
Also I would assume you have same image version on both controller and given AP model is compatible with it.
If not sure, pls post "show sysinfo" from both your WLC and "show version" from your AP.
Rasika
07-20-2016 07:43 PM
if you talking about "AP Authentication Policy".. no, none were setup
yes, AP model 3702i
WLCA 5508 iOS 8.0.133.0
WLCB 2504 iOS 8.0.133.0
07-20-2016 11:34 PM
Do your 2504 has enough license ? How many AP already in that WLC ? post the requested output for the sake of completeness, that may give some hint
Rasika
07-20-2016 11:37 PM
Hi Rasika, the issue solved. I'm not sure which command really fix it, but I think previously I did "capwap ap primary-base.." with WLC name in lower case, I try with upper case now it's working. but I repeat all the clear commands as well.
Thanks for your support.
