02-01-2019 10:55 AM - edited 07-05-2021 09:47 AM
Hello experts, I am setting up a new vWLAN Controller version 8.0.152.0 with AP1131AG access points.
The controller address is 172.16.10.5
the 2811 router is configured as
ip dhcp pool AP
network 172.16.10.0 255.255.255.0
default-gateway 172.16.10.1
option 43 hex f104.ac10.oa05
option 60 ascii "Cisco AP 1131"
dns-server 172.16.10.1
The error I get is: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
here is the boot log: Can you please assist ? thank you.
Username:
Username: Xmodem file system is available.
flashfs[0]: 26 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5280256
flashfs[0]: Bytes available: 10718720
flashfs[0]: flashfs fsck took 28 seconds.
Base ethernet MAC Address: 00:24:97:6e:2d:74
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1130-k9w8-mx.124-25e.JAP12/c1130-k9w8-mx.124-25e.JAP12"...#########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1130-k9w8-mx.124-25e.JAP12/c1130-k9w8-mx.124-25e.JAP12" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(25e)JAP12, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Fri 20-Oct-17 23:02 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[2]: 26 files, 8 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 15740928
flashfs[2]: Bytes used: 5280256
flashfs[2]: Bytes available: 10460672
flashfs[2]: flashfs fsck took 4 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0 present A506 7100 E8000000 A0000000 80000000 3
Rate table has 12 entries (0 SGI/0 BF variants)
Radio1 present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%Error opening flash:/c1130-rcvk9w8-mx/info (No such file or directory)cisco AIR-LAP1131AG-A-K9 (PowerPCElvis) processor (revision B0) with 27638K/5120K bytes of memory.
Processor board ID FTX1315T21N
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 8.0.141.32
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:24:97:6E:2D:74
Part Number : 73-8962-14
PCA Assembly Number : 800-24818-13
PCA Revision Number : A0
PCB Serial Number : FOC13142Q02
Top Assembly Part Number : 800-29230-02
Top Assembly Serial Number : FTX1315T21N
Top Revision Number : A0
Product/Model Number : AIR-AP1131AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:05.456: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:07.070: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar 1 00:00:07.546: %LINK-6-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.734: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar 1 00:00:08.807: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.834: %LWAPP-4-CLIENTEVENTLOG: Read and initialized AP event log (contains, 986 messages)
*Mar 1 00:00:11.116: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:11.117: %SNMP-5-COLDSTART: SNMP agent on host AP0024.976e.2d74 is undergoing a cold start
*Mar 1 00:55:23.257: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:55:23.257: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:55:23.257: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:55:23.493: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:55:23.493: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:55:24.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:55:24.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:55:26.061: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:55:31.383: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.10.93, mask 255.255.255.0, hostname AP0024.976e.2d74
*Mar 1 00:55:41.877: Logging LWAPP message to 255.255.255.255.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (172.16.10.1) [OK]
Translating "CISCO-LWAPP-CONTROLLER"...domain server (172.16.10.1) [OK]
*Mar 1 00:55:52.919: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.10.5 obtained through DHCP
*Mar 1 00:55:52.919: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:55:55.582: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar 1 00:55:56.614: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:55:57.614: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:55:57.653: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:55:58.654: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Not in Bound state.
The AP recycles and assign itself a new dhcp address each time/cycle...
02-19-2019 09:56 AM
John,
From the shared logs the config looks okay. The SN confirms that you are not running into CSCuq19142 which is common in old APs. Although 2 APs will soon hit the cert expiration. For more information see:
https://supportforums.cisco.com/document/12453081/lightweight-ap-fail-create-capwaplwapp-connection-due-certificate-expiration
Can you share the output of "show interface summary" from WLC CLI and "show ip int br" from AP CLI. Need to confirm ap manager config from interfaces.
-Sri
02-19-2019 10:46 AM
Thank you Srkala
Here is the print-outs:
(Cisco Controller)
User: admin
Password:*********
(Cisco Controller) >show interface summary
Number of Interfaces.......................... 3
Interface Name Port Vlan Id IP Address Type Ap Mgr Gu est
management 1 10 172.16.10.5 Static Yes No
service-port N/A N/A 10.100.10.151 Static No No
virtual N/A N/A 1.1.1.1 Static No No
AP0024.976e.2d74#sh ip interface brief
BVI1 172.16.20.122 YES DHCP up up
Dot11Radio0 unassigned NO unset up up
Dot11Radio1 unassigned NO unset up up
FastEthernet0 unassigned NO unset up up
AP0024.976e.2d74#
02-19-2019 11:14 AM
John,
Try to use static IP address on the AP as Leo mentioned earlier. The command is "capwap ap ip address A.B.C.D" and "capwap ap controller ip address 172.16.10.5" from AP CLI.
Is there any firewall between AP and WLC blocking UDP 5246 port ?
02-19-2019 12:34 PM
Thank you Srkala,
This is a LAB environment for a certification I am doing. I moved the AP to the 172.16.10.0/24 VLAN to simplify and not to deal with DGW.
I was able to set the static IP using the capwap command, but once it's set, the same errors comes up, the AP forces itself onto DHCP, and then reboots:
AP0024.976e.2d74#capwap ap ip address 172.16.10.110 255.255.255.0
You should configure Domain and Name Server from controller CLI/GUI.
AP0024.976e.2d74#capwap ap controller ip address 172.16.10.5
sh run | begin username
username Cisco secret 5 $1$J9Cy$w9NnSwTWn.x3Fw0z0dgqs.
ip ssh version 2
interface Dot11Radio0
no ip route-cache
mbssid
power local -1
power client local
packet retries 64 drop-packet
no cdp enable
interface Dot11Radio1
no ip route-cache
peakdetect
mbssid
power local -1
power client local
no cdp enable
interface FastEthernet0
no ip route-cache
duplex auto
speed auto
interface BVI1
no ip route-cache
no ip http server
logging trap emergencies
logging origin-id string AP:0024.976e.2d74
logging facility kern
logging snmp-trap notifications
logging snmp-trap informational
logging snmp-trap debugging
logging 255.255.255.255
control-plane
line con 0
line vty 0 4
transport input none
line vty 5 15
end
AP0024.976e.2d74#
*Mar 1 00:08:34.682: %CAPWAP-3-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP.
*Mar 1 00:08:39.695: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar 1 00:08:39.815: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.10.119, mask 255.255.255.0, hostname AP0024.976e.2d74
*Mar 1 00:08:45.689: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.10.5 obtained through DHCP
*Mar 1 00:08:45.689: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Not in Bound state.
*Mar 1 00:09:31.705: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:09:36.711: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar 1 00:09:36.831: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.10.120, mask 255.255.255.0, hostname AP0024.976e.2d74
Writing out the event log to nvram...
*Mar 1 00:09:42.784: %SYS-5-RELOAD: Reload requested by CAPWAP CLIENT. Reload Reason: Could not discover WLC using DHCP IP address, Reload to use static IP.
*Mar 1 00:09:42.787: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
AP0024.976e.2d74#Xmodem file system is available.
flashfs[0]: 25 files, 8 directories
flashfs[0]: Bytes used: 5217280
flashfs[0]: Bytes available: 10781696
flashfs[0]: flashfs fsck took 30 seconds.
Reset done!
here is a simple diagram of the environment, no firewall:
02-19-2019 04:01 PM
Hi John,
Just to double check, did you enable Promiscuous mode under your network settings for your vWLC?
Step 14 to 18 as per the guide below.
02-19-2019 05:59 PM
