AP1142 cli clear command missing
Hello all,
I'm using a WLC 5508 and light weight 1142 AP's with software version 7.0.116
I  wonder why there is no cli-clear or cli-reload command if I am  connected via SSH/telnet to an access point. When I connect through  console port there are this commands available. Is this a configuration  issue?
Any ideas? Thanks in advance.
Robert
5 Replies 5
Scott Fella
I was able to ssh to my 1142 and do a clear and reload command.  Did you make sure you are in enable mode?  I'm running 7.0.220.0, but I don't think that matters.
-Scott
Yes, i've been in enable mode. i will try the new software image.
Keep us posted if that does indeed fix it.
-Scott
shame on me
I've worked with the default login and password. After changing it in global config dialog at my WLC, I can see much more commands at the cli prompt.
At least you got it working.
-Scott
