AP1142N - Office and guest SSIDs and security
iholdings
Greetings,
I need assistance with configuring separate SSIDs for a remote offfice connected back to the corporate office over an L2L IPSEC.
I would like to configure an Office SSID using strong excryption - but hesitate deploying WPA or WPA2 since the authentication server I would need to include is on the corporate network across the tunnel.  Is there any way to use WPA/WPA2 without the need of a RADIUS server?
The Guest access should be open (perhaps).
Are there any good configuration examples or discussions that would help me?
Scott Fella
I'm guessing your AP's are autonomous and you don't have a WLC. You can still use WPA/Tkip or WPA2/AES using a preshared key. Here is a good doc to help you get started.
http://www.cisco.com/en/US/docs/wireless/access_point/1140/autonomous/getting_started/guide/ap1140aut_getstart.html
-Scott
Leo Laohoo
As what Scott has posted, you can use PSK but make creative use of your PSK.  Experience have taught me that PSK tends to be abused with time.
Guess what's going to happen?  Your staff will be joining the Guest SSID in the future.
George Stefanick
For sake of understanding...
WPA / WPA2 - SOHO or PSK is Preshare Key
WPA / WPA2 - Enterprise is the use of Radius (authentication)
