06-07-2019 01:00 AM - edited 07-05-2021 10:31 AM
Good morning!
I have an issue with a AP1702i configured as wgb. We use ISE for the authentication of our clients (with EAP-TLS).
The wgb is supposed to connect as client to another lightweight AP. Since the authentication is not even forwarded to the ISE by the WLC, I skiped the certifcate stuff from the config. The AP fails to connect untill it is excluded by the wlc.
AP config:
hostname AP-WGB
no aaa new-model
no ip source-route
no ip cef
ip domain name <domain>
ip name-server <DNS-server>
dot11 pause-time 100
dot11 syslog
dot11 ssid <my-ssid>
authentication network-eap eap-methods
authentication key-management wpa version 2
dot1x credentials EAP-TLS
dot1x eap profile EAP-TLS
eap profile EAP-TLS
method tls
username AP-WGB
pki-trustpoint AP-WGB
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
ssid <my-ssid>
antenna gain 0
stbc
station-role workgroup-bridge
bridge-group 1
bridge-group 1 spanning-disabled
On the WLC I see the following messages, wich are very confusing, since I have not set anything about web-auth...
debug client output:
*apfMsConnTask_3: Jun 07 08:43:32.066: 70:7d:b9:69:9a:e8 0.0.0.0 START (0) Web-auth is not supported for WGB, drop the association request!
*apfMsConnTask_3: Jun 07 08:43:32.066: 70:7d:b9:69:9a:e8 Scheduling deletion of Mobile Station: (callerId: 22) in 3 seconds
*osapiBsnTimer: Jun 07 08:43:35.025: 70:7d:b9:69:9a:e8 apfMsExpireCallback (apf_ms.c:632) Expiring Mobile!
*apfReceiveTask: Jun 07 08:43:35.025: 70:7d:b9:69:9a:e8 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfReceiveTask: Jun 07 08:43:35.025: 70:7d:b9:69:9a:e8 0.0.0.0 START (0) Deleted mobile LWAPP rule on AP [58:bf:ea:24:c2:00]
*apfReceiveTask: Jun 07 08:43:35.025: 70:7d:b9:69:9a:e8 Deleting mobile on AP 58:bf:ea:24:c2:00(0)
*apfMsConnTask_2: Jun 07 08:43:37.060: 70:7d:b9:69:9a:e8 Processing assoc-req station:70:7d:b9:69:9a:e8 AP:58:bf:ea:0f:78:e0-00 thread:15117bd0
*apfMsConnTask_2: Jun 07 08:43:37.061: 70:7d:b9:69:9a:e8 Adding mobile on LWAPP AP 58:bf:ea:0f:78:e0(0)
*apfMsConnTask_2: Jun 07 08:43:37.061: 70:7d:b9:69:9a:e8 Association received from mobile on BSSID 58:bf:ea:0f:78:f4 AP AP-06-04-01
*apfMsConnTask_2: Jun 07 08:43:37.061: 70:7d:b9:69:9a:e8 Global 200 Clients are allowed to AP radio
AP SW:
ap3g2-k9w7-xx.153-3.JI4
WLC:
8.0.121.0
Google could find a discussion here, but it is not avilable anymore...
Any ideas are highly appreciated!
best regards
Matt
Solved! Go to Solution.
06-20-2019 05:00 AM
06-07-2019 05:42 AM
Did this work before or new?
Is Aironet IE enabled on the WLAN? If not, try enabling it and test.
Make sure AP has NTP config and clock is right.
Reference for config and troubleshoot:
06-17-2019 07:27 AM
Aironet IE is enabled.
ntp is configured, but since there was no propper connection established, I set the time manually.
Thanks for the link, I will work through it tomorrow.
06-08-2019 06:40 AM
06-20-2019 05:00 AM
