AP1815m wont join WLC5520, but joins WLC5508 with same Firmware
d.novakovic
migrated today many APs to some new WLC 5520 with 8.5.151.0.
All these APs did run on a 5508 with same firmware.
ONLY this model 1815m wont join.
No AP autorization list, no fw blocking ports, ap licenses ok, system time is OK per NTP.
Maybe the 5520 needs some "AP Software Bundle" to be installed?
But did not find it at Cisco download side (like i did before in prior releases..)
Ideas?
2 Accepted Solutions
Remember, capwap traffic is UDP, depending on the firewall it doesn't log it.
Simple Reason (ARGGGAAAAHH!!!)  :-)
Not only the AP need to access WLC, but also WLC must initiate Traffic towards Access Points.
So Firewall Policies in the path blocked some traffic from WLC to Access Points.
11 Replies 11
Leo Laohoo
On the new WLC, post the complete output to the following command:
sh ap join stats detail <AP MAC ADDRESS>
Scott Fella
So what you are saying is that the 1815m will join the 5508 but not the 5520? You might need to look at the output on the console and see what is happening.
-Scott
Thanks for your reply!
Tested now with another 1815m from another location, and it JOINED perfectly the 5520.
Only 1815m from a some different location wont join.
So its not problem of the AP, WLC or Firmware, it must be something else i would say.
Investigating Monday what the heck. Maybe some FW i dont know blocking in the path?
Or MTU Issue..
The command i dont see any join entries for the MAC of that AP that wont join.
Have you power cycled the affected AP? Maybe it's hanging.
The first thing that pops into my mind is a certificate problem. Had this issue a long time ago and as I recall, I had to add the AP's MAC under MAC filtering.
Hi ..
well, as written befor, from ANOTHER LOCATION a 1815m CAN join the WLC.
So no problem with AP Model, compatibility, licenses, ap-bundle, firmware - all OK.
And no AP autorization list etc, no NTP time issue.
So seems like Firewall problem blocking CAPWAP between that location and WLC.
But i checked all Firewalls and traffic is coming and passing Firewall, and also traffic from WLC comes back.
But the AP WILL NOT join from specific locations.
I will contact TAC. Curious what it is this time!
It goes through Firewall.
On the WLC i get some output:
(Cisco Controller) >debug capwap errors enable
(Cisco Controller) >d*spamApTask5: Jun 15 14:41:45.086: 7c:31:0e:8a:3e:40 ApMode l: AIR-AP1815M-E-K9
*spamApTask3: Jun 15 14:42:11.540: 2c:4f:52:1c:42:a0 ApModel: AIR-AP1815M-E-K9
e*spamApTask5: Jun 15 14:42:17.175: 68:86:a7:7e:9b:d0 Received replay error(slot = 0, vapId = 1, count = 2) from AP 68:86:a7:7e:9b:d0
*sshpmLscTask: Jun 15 14:42:22.336: sshpmLscTask: LSC Task received a message 4
(Cisco Controller) debug>
(Cisco Controller) debug>*spamApTask5: Jun 15 14:43:39.138: 7c:31:0e:8a:3e:40 ApModel: AIR-AP1815M-E-K9
*spamApTask3: Jun 15 14:44:05.595: 2c:4f:52:1c:42:a0 ApModel: AIR-AP1815M-E-K9
*spamApTask5: Jun 15 14:44:16.429: 68:86:a7:7e:9b:d0 Received replay error(slot = 0, vapId = 1, count = 1) from AP 68:86:a7:7e:9b:d0
*sshpmLscTask: Jun 15 14:44:22.476: sshpmLscTask: LSC Task received a message 4
Can you check if there are still free licenses on the wlc with:
show license summary
Feature name: ap_count (adder)
License type: Permanent
License state: Active, In-use
RTU License Count: 250
247 APs connected, 3 AP Licenses left. So its OK.
Opened TAC Case. Curios!!!! :-)
