ap801 DotRadio dissapeared
Greg Maaaag
Good day!
We've got cisco 881w with wireless ap801 and after updating ios on ap801 interface DotRadio has dissapeared.
Boot image ap801-k9w7-tar.124-21a.JY
Is there any opportunity to fix it?
11 Replies 11
Scott Fella
When rebooting the ap, do you see any errors? Have you tried to downgrade back to the code you originally had?
-Scott
I've tried several ios and nothing:( i've tried with comman archieve download-sw and i've trined from bootloader.
So do you see an error when you are seasoned into the ap while the ap is rebooting. Can you post that an any other info so we have a better idea.
-Scott
Yes, ofcource:
ap_it#reload
Proceed with reload? [confirm]
*Mar  1 04:29:00.238: %SYS-5-RELOAD: Reload requested by console. Reload Reason:        Reload Command.
IOS Bootloader - Starting system.
FLASH CHIP:  Spansion Mirrorbit (0001)
Xmodem file system is available.
Bringing up flash file system:
flashfs[0]: 147 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31481856
flashfs[0]: Bytes used: 12687360
flashfs[0]: Bytes available: 18794496
flashfs[0]: flashfs fsck took 14 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 64:00:f1:78:08:74
Ethernet Interface initialize.
Ethernet Interface initialize OK.
TFTP initialize OK.
Boot system image.
Loading "flash:/ap801-k9w7-mx.124-10b.JDA3/ap801-k9w7-mx.124-10b.JDA3"...
File "flash:/ap801-k9w7-mx.124-10b.JDA3/ap801-k9w7-mx.124-10b.JDA3" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 12.4(10b)JDA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 07-Jun-09 04:01 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01000000
Initializing flashfs...
flashfs[1]: 147 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31481856
flashfs[1]: Bytes used: 12687360
flashfs[1]: Bytes available: 18794496
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio 0 0 0 0 0 0 30
Radio 0 0 0 0 0 0 11
tx_paks 0
tx_paks 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AP801GN-E-K9         (PowerPC 8343) processor (revision B0) with 49142K/16384K bytes of memory.
Processor board ID FCZ1539C4KL
PowerPC 8343 CPU at 400Mhz, revision number 0x0031
Last reset from reload
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:00:F1:78:08:74
Part Number                          : 73-11027-11
PCA Assembly Number                  : 800-28807-11
PCA Revision Number                  : B0
PCB Serial Number                    : FOC15326R32
Top Assembly Part Number             : 800-29556-06
Top Assembly Serial Number           : FCZ1539C4KL
Top Revision Number                  : A0
Product/Model Number                 : AP801GN-E-K9
Press RETURN to get started!
*Mar  1 00:00:05.027: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:05.123: Warning: shutdown this internal interface will disrupt embedded AP operation!
*Mar  1 00:00:05.127: %LINK-4-NOMAC: A random default MAC address of 0000.0c05.0874 has
  been chosen.  Ensure that this address is unique, or specify MAC
  addresses for commands (such as 'novell routing') that allow the
  use of this address as a default.
*Mar  1 00:00:05.295:
Note: A random mac address of 0000.0cdd.14b0
      has been chosen for BVI in bridge group  1 since there is no mac address
      associated with the selected interface.
      Ensure that this address is unique.
*Mar  1 00:00:05.311:
Note: A random Spanning Tree Bridge Identifier address of 0000.0c94.14c0
      has been chosen for Bridge Group 1 since there is no mac address
*Mar  1 00:00:05.323: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:05.327: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:05.327: %SNMP-5-COLDSTART: SNMP agent on host ap_it is undergoing a cold start
*Mar  1 04:29:01.127: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 04:29:01.823: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 04:29:02.839: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 04:29:03.823: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 04:29:04.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar  1 04:29:11.947: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar  1 04:29:12.947: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
ap_it>enable
Password:
ap_it#show interfaces
BVI1 is up, line protocol is up
  Hardware is BVI, address is 0000.0cdd.14b0 (bia 0000.0c05.0874)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 5000 usec,
  Last input never, output never, output hang never
  5 minute input rate 1000 bits/sec, 3 packets/sec
     301 packets input, 18060 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
GigabitEthernet0 is up, line protocol is up
  Hardware is PowerPC 8343 Ethernet, address is 6400.f178.0874 (bia 6400.f178.0874)
  Description: the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is internal
  output flow-control is unsupported, input flow-control is XON
  Last input 00:00:00, output 00:00:04, output hang never
  Input queue: 0/1677/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4000 bits/sec, 6 packets/sec
     535 packets input, 37683 bytes, 0 no buffer
     Received 507 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     17 packets output, 2196 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
Not good... can you do a show hardware?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
thank you for your help!) how can i show you hardware?
From the session connection to the ap, issues a show hardware. That will show the interfaces that the ap knows of.
-Scott
ap_it#show hardware
E SOFTWARE (fc1)
ROM: Bootstrap program is AP801 boot loader
BOOTLDR: AP801 Boot Loader (AP801-BOOT-M) Version 12.4(23c)JX, RELEASE SOFTWARE
(fc1)
ap_it uptime is 15 hours, 50 minutes
System returned to ROM by reload
System image file is "flash:/ap801-k9w7-mx.124-10b.JDA3/ap801-k9w7-mx.124-10b.JD
A3"
export@cisco.com.
Configuration register is 0xF
Well it looks like your AP AP interfaces are dead.  You should RMA your device. You should see your 802.11 Radios:
cisco AP801AGN-A-K9        (PowerPC 8343) processor (revision B0) with 49142K/16384K bytes of memory.
Processor board ID FTX151502AU
Last reset from power-on
LWAPP image version 7.3.101.0
2 802.11 Radios
2 802.11 Radios
Scott
-Scott
what does RMA means?
Here is a link regarding the Cisco limited lifetime warranty. You should be able to call Cisco and open a case to RMA the equipment.
Hope this help
http://www.cisco.com/en/US/docs/general/warranty/English/LH2DEN__.html
-Scott
