08-27-2018 03:28 AM - edited 07-05-2021 09:02 AM
Autonomous APs with same SSID
Hello.. i have been looking to install four cisco 2700 Access Points with same SSID. These APs will be connected to Broadband Router acting as NAT & DHCP.
What is best way to configure four APs so that there is no conflicts and Roaming also work.
Really dont want clients get frustrated on wifi connectivity.
08-27-2018 04:10 AM
You can configure those 4 AP like below (use four different hostnames). Keep SSID name & password same across 4 APs.
conf t
hostname <AP_HOSTNAME>
dot11 ssid <SSID_NAME>
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii <SSID_PASSWORD>
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid <SSID_NAME>
no shutdown
interface Dot11Radio1
channel width 40-above
ssid <SSID_NAME>
no shutdown
interface BVI1
ip address dhcp
end
write memory
Rasika
*** Pls rate all useful responses ***
08-27-2018 09:17 PM
Hi Rasika,
Thanks for response, could you please confirm that with this config on all 4 APs there will no conflicts in SSID and end clients, also roaming also work.
08-27-2018 09:57 PM
Anukalp,
Yes Rasikas configuration will work.
Mkae sure you have diff hostname and diff IP for BVI interface for each AP, rest all configration will be same.
Dont forget to rate helpful posts
08-28-2018 06:11 AM
Thanks, will setup this & confirm.
08-27-2018 04:12 AM - edited 08-27-2018 04:13 AM
Check these post, some have answered already for your question.
Check these posts:
https://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
https://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
https://mrncciew.com/category/autonomous-ap-config/
https://mrncciew.com/2012/10/24/multiple-ssid-config-on-autonomous-ap/
