12-03-2019 09:38 AM - edited 07-05-2021 11:22 AM
We have an existing concert hall that was never planned for WiFi coverage. We will have to do runs for the lower level.
A picture is below. The upper level can hold 570 people. The facility is about 100x100 feet with the inner portion of 68x75' being open to a lower level which can hold 250 people and has a 68x50' stage. There is expanding stadium style seating that retracts back under the upper level when not in use. Certain events will use the seating and others will be standing. About the same number of people will be the maximum (250 in the lower level) either way.
The upper level we have enough drops to get adequate coverage, but we worry about the lower level. We can run copper and are hoping 4 AP's with patch antennas facing inward will cover it.
The walls at the lower level are 12-20' tall as they slope to the back and the upper ceiling is about 50-60' high.
We are using Cisco AP's on a WLC now.
Any thoughts of covering this space efficiently?
12-03-2019 10:00 AM
12-03-2019 01:06 PM
12-09-2019 06:52 AM
They are looking to do this on a budget, I was hoping there would be someone that covered a similar simple area like this.
Is there a way we can do our own survey? Most of the software out there that is low cost to free doesn't really survey.
I am Ekahau certified myself and a wireless CCNA, but I don't have the tools I need.
