06-11-2011 03:54 AM - edited 07-03-2021 08:18 PM
i have 1242ag series autonomous AP.
I want to broadcast more than one SSID.
pls tell me the step by step approach by considering that i am new to the concepts of radio a g etc.
Solved! Go to Solution.
06-14-2011 02:44 AM
thats one of the difference between the LWAPP and the Autonomous APs.. Thats y i mentioned "Its the Thumb Rule in Autonomous"
Surendra
06-11-2011 04:14 AM
Hi Vishal,
the configuration you need is the MBSSID, described here:
The step-by-step instructions from both GUI and CLI are described at this paragraph:
In a nutshell, from CLI, you enable "mbssid" under the dot11radio[0|1]:
ap(config)# interface d0
ap(config-if)# mbssid
ap(config-if)# exit
Then, you add the "mbssid guest-mode" within the SSID config:
ap(config)# dot11 ssid visitor
ap(config-ssid)# mbssid guest-mode dtim-period 75
ap(config-ssid)# exit
Then you enable the SSID on the dot11radio interface:
ap(config-if)# ssid visitor
I hope this helps.
Federico
If this answers your question please mark the question as "answered" and rate it, so other users can easily find it.
06-13-2011 01:20 AM
hi federico,
thanx for the step by step explaination.
I entered above cmds, but Radio0-802.11G shwowing me disabled.
Kindly suggest.
06-13-2011 04:47 AM
hi,
can i create multiple SSIDs without using vlans??
06-13-2011 09:20 AM
No we cannot.. In Autonomous Infra structure.. its always 1:1 mapping.. that is 1 VLAN : 1 SSID mapping..
Lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
06-13-2011 11:09 PM
hi surendra,
i have created multiple ssids without vlans, but radio of AP is showing me disabled.
lemme knw if u want extra info on this.
06-13-2011 11:11 PM
Yes thats expected!! Its the Thumb Rule in Autonomous to use 1 SSID to 1 VLAN that is 1:1 Mapping.. wlse the Radio will not come up!!
Surendra
06-14-2011 01:55 AM
hi,
but when i configure multiple SSIDs on lightweight AP, it works.
06-14-2011 02:44 AM
Surendra
06-14-2011 09:52 PM
hmmm... ok. thank you surendra
