260
Beginner
C9120AXI-EWC and C9120AXI embedded wireless controller
Hello everyone
The Access Point C9120AXI-EWC can be converted to C9120AXI and vice versa
embedded wireless controller Can it be migrated to a physical controller or to the cloud as it could be?
If it were possible, would it have any cost?
Thanks in advance
2 ACCEPTED SOLUTIONS
Hall of Fame Community Legend
Re: C9120AXI-EWC and C9120AXI embedded wireless controller
When you generate a quote, you can specify what firmware you want pre-loaded: EWC/ME or CAPWAP.
And here's the gotcha: You will also need a valid Service Contract to be able to download either of the firmware.
If the AP will be converted to CAPWAP, a valid Service Contract for the WLC is required. If downloading EWC, a valid Service Contract for the "controller" AP is required.
However, sometimes one can download the EWC/ME firmware without a valid Service Contract.  For example, if you read THIS and scroll down to "Customers Without Service Contract Section" ...
Hall of Fame Master
I think you will have to wait and see. I think maybe there is cost for license for ewc just like ios. I would believe the software is free if you have support.
-Scott
7 REPLIES 7
Highlighted
Is the term "EWC" now being using by Marketing, is it?
If EWC is Mobility Express, then yes. The AP can be converted from Mobility Express/EWC to CAPWAP (and vice versa).
NOTE: I think the terms changed because Mobility Express firmware was free.
Hall of Fame Master
I guess you have to wait to see if the code comes out and the process to change the image.
-Scott
Beginner
Beginner
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9120ax-series-access-points/datasheet-c78-742115.html?oid=powen019216
Cisco Catalyst 9120I Access Point: Indoor environments, with internal antennas
●  C9120AXI-x: Cisco Catalyst 9120 Series
Cisco Catalyst 9120I Access Point: Indoor environments, with internal antennas, with embedded wireless controller
●  C9120AXI-EWC-x: Cisco Catalyst 9120 Series
the  Cisco Embedded Wireless Controller on Catalyst Access Points document says:
It does not indicate cost or the way to do it
Hall of Fame Master
-Scott
Beginner
Thanks everyone for your help
Content for Community-Ad
August's Community Spotlight Awards
