07-17-2019 04:45 AM - edited 07-05-2021 10:43 AM
Maybe these days somebody struggles the same way like I did last week.
So if you want to use the embedded 9800 WLC (often called eWLC) on a catalyst 9300 switch. You have to download the special releases from this site: https://www.cisco.com/c/en/us/solutions/enterprise-networks/software-defined-access/compatibility-matrix.html
At the moment the only working release is 16.10.1e: (https://software.cisco.com/download/specialrelease/243cab156106f62a25ae3932eb2ecc62) don't forget to download both, the correct switch image and the corresponding eWLC image.
If you have both images ready and the c9300 switch on 16.10.1e, you can follow these instructions to deploy the eWLC: https://community.cisco.com/kxiwq67737/attachments/kxiwq67737/4461-docs-network-infrastructure/6089/1/SD%20AccessEmbeddedCat9800_1.2.10.pdf
Log in to Community
