Highlighted
Beginner
Can 6506-E provide POE for Aironet 1142
release note for Aironet 1200 series said 6500 CANNOT provide POE for 1200 series.  But how about 1142?
I have a new 1142 connected on my 6506-E, but it cannot power on.
On 1142's datesheet, it has a list of  compliant devices, 6500 is not in the list.00
Can 6506-E POE Aironet 1142?
p.s. I certainly enabled POE on the port.
Thanks so much.
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Master
That is not PoE...
48-Port 10/100/1000 Ethernet ModuleWS-X6148A-GE-TXProduct Page
Data Sheet
48-Port 10/100/1000 Ethernet Module with Power over Ethernet (PoE) 802.3afWS-X6148A-GE-45AFProduct Page
Data Sheet
-Scott
7 REPLIES 7
Hall of Fame Master
Re: Can 6506-E provide POE for Aironet 1142
It should:
Powering Options
• 802.3af Ethernet Switch
• Cisco AP1140 Power Injectors (AIR-PWRINJ4=)
• Cisco AP1140 Local Power Supply (AIR-PWR-B=)
What do you see when you run a show power inline ?
-Scott
Beginner
the AP was power off, LED was off, the interfacw showed not connected.
Hall of Fame Community Legend
The 6500 alone isn't responsible with PoE.  It's the line card.  Can you kindly post the output to the command "sh module"?
Beginner
WS-X6148A-GE-TX  this is my line card.
Thanks a lot.
Hall of Fame Master
That is not PoE...
Data Sheet
Data Sheet
-Scott
Beginner
Thanks a lot.  I found this on Cisco web-site as well. unexpected....
PoE line cards for the 6500 have the "AF" suffix.
Content for Community-Ad
August's Community Spotlight Awards
