03-18-2015 09:52 AM - edited 07-05-2021 02:44 AM
We were recently gifted some Aironet units (AIR-SAP26021-A-K9) but unfortunately they came without the Wireless LAN Controllers. Is there any possibility of using them as APs while we wait to procure the controllers?
Our procurement processes are rather long, made even more so because we'll have to procure from overseas.
Dannie
Solved! Go to Solution.
03-18-2015 12:25 PM
Yes, they can.
If they came up with a LightWeight ( something like k9w8 in image name) you have to convert it to Autonomous (image name with k9w7) code. You have to get the required autonomous image & that require a valid maintenance contract with Cisco (otherwise you have to approach a Cisco partner & see if they can help)
Here is the conversion processs in case you got the AP with lightweight image.
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Once you converted, you can do a basic configuration like below & connect it to DHCP enable switchport to get your wireless AP working.
conf t hostname <AP_HOSTNAME> ! dot11 ssid <SSID_NAME> authentication open authentication key-management wpa version 2 guest-mode wpa-psk ascii <SSID_PASSWORD> ! interface Dot11Radio0 encryption mode ciphers aes-ccm ssid <SSID_NAME> no shutdown ! interface Dot11Radio1 encryption mode ciphers aes-ccm ssid <SSID_NAME> no shutdown ! interface BVI1 ip address dhcp ! end write memory !
Rasika
**** Pls rate all useful responses ****
03-18-2015 12:25 PM
Yes, they can.
Rasika
05-22-2015 12:48 PM
Thanks Nicolas for endorsement.
05-26-2015 03:58 PM
2600 series access point is available in both controller-based (Unified) and standalone (Autonomous) configurations and supports:
Please refer to the below link for more information on 2600 series :
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/2600/quick/guide/ap2600getstart.html
