Community Helping Community
664
Beginner
Can a single Access Point support both bridge mode and Access Point mode at the same time
Hi Guys
Does anyone know which access point can work in both bridge mode and AP mode ?
Cheers
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: Can a single Access Point support both bridge mode and Acces
Those are really the only option for you for that design. You can use an indoor ap, but you would have to keep the ap inside and cable to an external antenna at each location.
Scott Fella
Sent from my iPhone
-Scott
7 REPLIES 7
Hall of Fame Master
If its dual radios and autonomous you can. You can bridge one radio and use the other for client access.
Scott Fella
Sent from my iPhone
-Scott
Beginner
Hey Scott
Thanks for your help.
Autononmous means you cannot control them using wireless controller ?
Do you suggest any outdoor AP that can do this ?
Cheers
Hall of Fame Master
Well what are you trying to cover. If its really a large outdoor area, then look at the mesh AP. Those require a WLC. Autonomous or stand alone ap can perform bridging on one radio and client access on another. You can also look at AP that support indoor mesh that also controlled by a wlc. If your putting APs outdoors, then look at the outdoor mesh.
Scott Fella
Sent from my iPhone
-Scott
Beginner
Hi Mate,
I am deploying this at a Motel which has 15 dongas most of them have 3 rooms; total of 36 rooms. . Area is 4000m. I was initially looking for an mesh network; but could only find 1500 series that can do mesh and these are expensive. Do you know if there is any other outdoor AP that can work as mesh network.
Cheers
Highlighted
Hall of Fame Master
Scott Fella
Sent from my iPhone
-Scott
Beginner
Thanks Scott
I will either design the solution with mesh network or use indoor AP's with external antennas.
Cheers
Beginner
You can use 1240 or 1250 autonomous AP in workgroup bridge mode. Using workgroup bridge u can connect to the WLC and other interface can be configured as root so this will provide you an option to server the clients as well as manage them using your WLC
Content for Community-Ad
August's Community Spotlight Awards
