Highlighted
Beginner
Can autonomous and LAPs co-exist?
I have an existing roaming 2.4 wireless network which consists of 4 autonomous 1242 APs. I need to expand the coverage area.
Can I add a controller and LAPs with the same SSID and expect my clients to roam from the autonomous AP to the LAP?
Or do I need to replace the 4 1242s with LAPs?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: Can autonomous and LAPs co-exist?
4 REPLIES 4
Highlighted
Hall of Fame Master
You do not want to mix them. If you get a WLC, then you can convert the autonomous AP's to lightweight.
-Scott
Highlighted
Hall of Fame Master
Highlighted
Beginner
Can autonomous 1242AG APs be converted to work with Cisco 2500 WLC?
Thanks!
Highlighted
Hall of Fame Master
Yes... I just posted some links on the instructions to convert them on my previous post.
-Scott
Content for Community-Ad
