20200
Highlighted
Beginner
Can I convert a AIR-LAP1041N-E-K9 as standalone ?
I have a brand new AIR-LAP1041N-X-K9 Access Point I want to use as standalone device (without WLC controller).
Is it possible to convert it to become a AIR-AP1041N-x-K9 standalone Access point ?
Here is the show version output :
AP70ca.9b04.ee00#sh version
Cisco IOS Software, C1040 Software (C1140-RCVK9W8-M), Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 12:53 by prod_rel_team
ROM: Bootstrap program is C1040 boot loader
BOOTLDR: C1040 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA1, RELEASE SOFTWARE (fc1)
AP70ca.9b04.ee00 uptime is 3 hours, 41 minutes
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"
cisco AIR-LAP1041N-E-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1541W0M1
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.0.94.21
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 70:CA:9B:04:EE:00
Part Number                          : 73-14034-03
PCA Assembly Number          : 800-34273-04
PCA Revision Number            : A0
PCB Serial Number                : FOC153813TT
Top Assembly Part Number     : 800-34284-02
Top Assembly Serial Number   : FCZ1541W0M1
Top Revision Number               : A0
Product/Model Number            : AIR-LAP1041N-E-K9
Configuration register is 0xF
If it is possible, what procedure should I follow ?
Thank you for any help !
Yves
Everyone's tags (3)
1 ACCEPTED SOLUTION
Contributor
5 REPLIES 5
Contributor
Beginner
Thanks a lot for your suggestion and interesting link. I tried it but it seems that this procedure works with 1100 and 1200 Series of Access Points, that can run in both modes, but I have a 1040 Serie and it does not semm to be supported. Actually, the access point keep looping in DHCP requests and never falls in the default IP address process...
Do you think that the LAP-1041N does not support the autonomous mode ?
Thanks a lot for your help
Yves
Hall of Fame Master
Re: Can I convert a AIR-LAP1041N-E-K9 as standalone ?
You need to convert the AP first. That ap that you have requires a WLC. So of you want to use it as a stand alone ap you need I convert it to autonomous and then configure the ap.
Sent from my iPhone
-Scott
Hall of Fame Master
See this link also
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
Sent from my iPhone
-Scott
Beginner
Hi all,
I answer now to my own question :-) I found an excellent link that complement the link from Nikhil :
http://b1tsnbyt3s.blogspot.com/2011/06/convert-cisco-lightweight-ap-to.html
I managed to change my LAP-1041N in a standalone Access point !
Thanks you for your support and guidance
Yves
Content for Community-Ad
August's Community Spotlight Awards
