Highlighted
Beginner
Can i use cisco Air 1410 Bridge and access point
Dear All
Please let me know if I has cisco air 1410 point to point wireless bridge and I want to used same device as access point to connect
laptops and mobiles.
Thanks in advance
I am waiting for your kind response
7 REPLIES 7
Highlighted
Beginner
it has only two modes, root bridge and nonroot bridge and it has only 5GHz.
So it will not support clients
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1400-wireless-bridge/product_data_sheet09186a008018495c.html
Highlighted
Thanks for your response
shall I use AIR-1552E for point to point bridge and access point
if root mode or non-root mode
please suggest me
Highlighted
Beginner
Yes it has 2.4GHz and 5GHz options.
5GHz you can use for backhaul and 2.4GHz for clients.
Highlighted
Thanks once again
I want to asked you which omani antenaa is best that cover long range clients
what is the maximum range it covers in meters or km.
Please advice me.
Highlighted
Please find the below link
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
Highlighted
As the coverage of  Omni antenna is obvious 360 Degree and range of antenna depends on many factors, 1st one is the antenna gain, In Cisco 1552E we have option to attach upto 8dBi gain, omnidirectional antenna for any of the frequency band
For 2.4GHz :
Check this 8dBi antenna product AIR-ANT2480V-N
For 5GHz :
Check this 8dBi antenna product AIR-ANT5180V-N
As, i have seen in my locality, practically 8dBi antenna is giving upto 800-1000 meter range in a diameter.
Highlighted
Enthusiast
Yes, It can not be work as an Access-point, Cisco 1410 is a Wireless Bridge, which have option to work as Root Bridge and non-Root Bridge,
