04-25-2017 12:35 PM - edited 07-05-2021 06:56 AM
I can't enable the 5Ghz radio on the AP AIR-AP2702I-UXK9, can't configure on root, can i change the -UX domain to another where i can use the 5GHz radio ? Also i'm getting a extreme low speed performance on 802.11ng clients.
ap(config-if)#station-role root
Error: Station role can be only scanner mode on 5G of universal AP in -UX domain
Thanks advanced.
Solved! Go to Solution.
04-25-2017 02:01 PM
First you have to prime this AP to country where you are in. Refer below for that
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ux-ap/guide/uxap-mobapp-g.html
Then only you can enable 5GHz on it.
Rasika
*** Pls rate all useful responses ***
04-25-2017 02:01 PM
Rasika
04-26-2017 09:22 AM
Thank you very much.
