Highlighted
Beginner
Beginner
Can we do redundancy in Cisco virtual wireless controller and how. I am using version 8.3.143
5 REPLIES 5
Highlighted
VIP Mentor
HI,
nee dto vWLCs..
you will need license on both vWLC. It will be normal AP license.
HA AP SSO isn't supported on the vWLC. You can have two vWLC doing redundancy with high availability configured on the AP.
Highlighted
Thanks Sundeep.
is there any version restriction. as per cisco documentation its only supported from 8.4 and above. my client is using 8.3.143 and not possible to upgrade it at this time.
Also, after configuring seconday controller in the HA tab, what is the best possible way to migrate the WAPs to secondry vWLC ?
Highlighted
As per my knowledge, you dont need to be on 8.4 version. It should also work with 8.3.143.0.
configure primary /Secondary WLC IP in AP HA tab and additionally, add both WLCs to each others mobility group as per this post:
https://rscciew.wordpress.com/2014/07/10/mobility-configuring-on-wlc/
Dont forget to rate helpful posts
Highlighted
Ho Sandeep thanks for quick response. i will try with the 8.3 and AP HA tab.
The link you have give is in regards to mobility. Will that be required given my scenario. Isn't configuring Primary/Secondary on WAP HA tab be enough for the WAPs to failover in case primary is offline ?
Highlighted
Yes it will be required. AP will not move to a controller that is not in the same mobility group as its current controller if that controller fails.
http://what-when-how.com/deploying-and-troubleshooting-cisco-wireless-lan-controllers/mobility-groups-cisco-wireless-lan-controllers/
