I have 2 5508 controllers that were originally used as standalone controllers. The APs have been moved to another controller and I want to set them up as an HA pair for a different group of APs. The service port isn't connected. Can I configure these as a pair remotely? Their mgmt. interface IPs are obviously different and I can't change either of them without causing an conflict. The HA ports are cabled. If I configure the redundancy management IPs and peers, configure one of the units as secondary will the fact that the mgmt. IP addresses are different cause a problem when I config maintenance mode sso? Or will they reboot and the secondary will assume the mgmt. IP of the primary?
