04-12-2013 09:17 AM - edited 07-03-2021 11:54 PM
After some searching I see many people using power injectors or switches that supploy PoE. I am building a lab for the CCNA Wireless and currently have an old Cisco 3550 PoE switch and a 2106 Controller that I got at a steal of a price. My question is, The 1142 can use the 15.4 Inline Power from the 3550 even though it is not the 802.11af standard correct? If it doesn't then I will need to order a power brick.
Solved! Go to Solution.
04-12-2013 10:29 AM
That will work... I have some old a$$ switches that I have powered up AP's on just for testing.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
04-12-2013 10:29 AM
Scott
04-12-2013 11:23 AM
Thanks a bunch!
04-12-2013 11:24 AM
No problem.
Scott
