Cisco 1152E as a Bridge
Nasir1111
Hi all,
Can we use Cisco aironet 1152E Mesh AP as a Point - to - Point bridge connecting 2 sites 1 Km apart.
Pls suggest the considerations before deplying.
Thanks in Advance
Nasir Manzoor
Amjad Abdullah
Hi Nasir,
I think you can use the mesh AP as a PTP link. But you have to enable ethernet bridging to achieve this.
check this: http://tiny.cc/325yiw
If this works for the 1Km distance, that all depends on your antenna.
Check mesh deployment guide about how to implement Point-to-Point links (enable ethernet bridging and that is it)
http://tiny.cc/005yiw
Amjad
Rating useful replies is more useful than saying "Thank you"
5 Replies 5
Scott Fella
Is that the correct part number?
-Scott
oops, its Cisco 1552E Mesh AP
That is pretty far for mesh especially for omni antennas on the 1552. You should go with a PTP bridge. Cisco sells the Exalt r5005 that will get you 160mbps.
-Scott
Hi Scott,
Thanks for the information, but i guess Exalt r5005 is not oderable from Cisco directly ?
If not Cisco Aironet 1550 AP , what about 1520, 1300, 1400 AP ???
Amjad Abdullah
Hi Nasir,
Amjad
