138
Beginner
Cisco 1702i access point not able to join 1832 mobility express.
Dear Community,
During the joining process of 1702i with 1832 mobility express i got the the following error.
*Apr 13 08:30:27.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.41 peer_port: 5246
*Apr 13 08:30:33.011: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_record.c:394 BD is not of DTLS Change Cipher Spec type
*Apr 13 08:30:33.011: %DTLS-5-SEND_ALERT: Send FATAL : Internal error Alert to 10.1.1.41:5246
*Apr 13 08:30:33.011: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.1.41:5246
*Apr 13 08:31:31.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Apr 13 08:31:32.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.41 peer_port: 5246
*Apr 13 08:31:32.000: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:929 Unexpected message received while expecting HelloVerifyRequest
*Apr 13 08:31:32.000: %DTLS-5-SEND_ALERT: Send FATAL : Unexpected message Alert to 10.1.1.41:5246
*Apr 13 08:31:32.000: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.1.41:5246
*Apr 13 08:32:46.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
KIndly Help.
2 REPLIES 2
Rising star
Re: Cisco 1702i access point not able to join 1832 mobility express.
1) look at this post for some optional causes
2) and this Field Notice: FN - 63916
that says: Some Wireless Access Points (APs) manufactured between August 2014 and October 2014 might have an incorrectly programmed SHA-2 certificate.
3) check the software version on the 1702 is compatible with the version ME version on the 1832
Cisco Mobility Express Solution Compatibility Matrix
Hello, try to use config ap dtls-version dtls_all command and check if the APs are able to connect to the WLC again.
Content for Community-Ad
August's Community Spotlight Awards
