Community Helping Community
865
Highlighted
Beginner
Cisco 2100 Series Controller, configure mutiple DHCP
We have a 2100 controller with 4 wireless AP's, only one connected directly to the controller. I want to use the controller for the DHCP server for Guest, thermostats, in house wireless networks on this system. I cannot seem to get the DHCP setup properly to assign an address according to the SSID they sign into.
GJN
Everyone's tags (2)
4 REPLIES 4
Rising star
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
You have posted your question in the Small Business Section. I think that you would get a better response by asking your question here: https://supportforums.cisco.com/community/netpro/wireless-mobility/begin-wireless
None of the Small Business Access Points use wireless controllers, so we can not adequately answer your question.
Eric Moyers
Cisco Network Support Engineer
CCNA, CCNA-Wireless
1-866-606-1866
Rising star
Re: Cisco 2100 Series Controller, configure mutiple DHCP
Per your suggestion, I have moved the discussion into the Getting Started with Wireless area for Gary so he doesn't need to repost.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Rising star
Thanks, wasn't sure how to do it, or if I could.
Eric
Outlook Cisco Signature
Hi Gary,
On the WLC you will want to click on the CONTROLLER and then select the wired side interface your WLAN is mapped to. On the bottom you will see a section for DHCP Server.
What do you have in that field?
Content for Community-Ad
August's Community Spotlight Awards
