10-05-2011 08:59 PM - edited 07-03-2021 08:52 PM
We have a 2100 controller with 4 wireless AP's, only one connected directly to the controller. I want to use the controller for the DHCP server for Guest, thermostats, in house wireless networks on this system. I cannot seem to get the DHCP setup properly to assign an address according to the SSID they sign into.
GJN
10-11-2011 11:37 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
You have posted your question in the Small Business Section. I think that you would get a better response by asking your question here: https://supportforums.cisco.com/community/netpro/wireless-mobility/begin-wireless
None of the Small Business Access Points use wireless controllers, so we can not adequately answer your question.
Eric Moyers
Cisco Network Support Engineer
CCNA, CCNA-Wireless
1-866-606-1866
10-11-2011 11:57 AM
Per your suggestion, I have moved the discussion into the Getting Started with Wireless area for Gary so he doesn't need to repost.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
10-11-2011 12:01 PM
10-11-2011 09:41 PM
Hi Gary,
On the WLC you will want to click on the CONTROLLER and then select the wired side interface your WLAN is mapped to. On the bottom you will see a section for DHCP Server.
What do you have in that field?
