Cisco 2504 and AP1702i
linuxwiz54
I was able to configure 2504 wireless controller once configured I plugged in the AP to POE port on 2504, I see the AP with Flashing Green but 2504 doesn't see the AP, what could be wrong any guidance will be appreciated.
To join 1702 series AP , you need minimum 8.0.100.0 SW version on WLC.
Check here the comptibility matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
6 Replies 6
I lost this post and finally found it
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_54:88:e4
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.x.x.2
Last Reset....................................... Power on reset
System Up Time................................... 0 days 8 hrs 50 mins 31 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +26 C
External Temperature............................. +29 C
Fan Status....................................... 3200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:42:5A:54:88:E0
Maximum number of APs supported.................. 5
AP
AP00d7.8f89.22d4>sh ver
Cisco IOS Software, C1700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JD, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 29-Jul-16 04:10 by prod_rel_team
ROM: Bootstrap program is C1700 boot loader
BOOTLDR: C1700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.3() [ TRUE]
AP00d7.8f89.22d4 uptime is 9 hours, 1 minute
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1702I-B-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW2041NLMD
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.102.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:D7:8F:89:22:D4
Part Number : 73-16776-01
PCB Serial Number : FOC20395SJM
Top Assembly Part Number : 068-100893-01
Top Assembly Serial Number : FCW2041NLMD
Top Revision Number : A0
Product/Model Number : AIR-CAP1702I-B-K9
Configuration register is 0xF
Thank you Sandeep I upgraded the firmware to 8.0.140 and connected AP and it worked.
Sandeep Choudhary
Paste the output of these commands:
sh version from AP
sh sysinfo from WLC.
Info: If you want to join AP, then you need to setup a dhcp scope on the wlc and make sure that it must be on the same network as the wlc management. The ap will get an ip address from the pool and join the wlc as long as everything else is configured correctly.
denizyaran
Is the POE port assigned to any interface and VLAN? And can the AP receive any address?
