Cisco 3504 Wireless controller goes into maintenance mode
Mikey John
Hi Folks,
 I have 2 x Cisco 3504 Wireless controllers connected to switches. There are currently two ports active on the WLCs towards the switches (both on Active and Standby WLC). These ports are part of a LAG, and there is port channel configured on the switch end as well. These two ports seem to be functioning well.
But, when I try and enable the remaining two ports on the WLCs (Active & standby) towards the switch, and bring them into the port channel, I see the standby WLC loses peer connectivity, and goes into maintenance mode.
(XXXX) >show redundancy summary
            Redundancy Mode = SSO ENABLED
                Local State = MAINTENANCE
                 Peer State = UNKNOWN - Communication Down
                       Unit = Primary
                    Unit ID = 70:18:A7:C9:3F:10
           Redundancy State = Non Redundant
               Mobility MAC = 70:18:A7:C9:3F:10
               Redundancy Port  = UP
               Link Encryption = ENABLED
Maintenance Mode = Enabled
Maintenance cause= Default Gateway not reachable
Appreciate your input on this issue.
Cheers
Mikey
11 Replies 11
Scott Fella
Check your configurations on the switch. Seems like the ether channel might be the issue. Adding or removing port connected to switches should not affect anything. Check the state of the port channel when you connect up the port.
-Scott
Hi Scott,
 The port channel looks ok. I can see those two ports being added to port channel, and it looks all fine to me. Still the same issue.
Sw1:
Members in this channel: Gi 0/27(U) Gi 0/28(U) Gi 0/29(U) Gi 0/30(U)
Sw2:
Cheers
Mikey
I don’t know… I have done that on a few models without any issues. I’m assuming you are using the correct ports to bundle not the mGig.
-Scott
Yep, I have used only the first 4 ports on both the WLCs.
(XXXX) >show port summary
STP Admin Physical Physical Link Link
Pr Type Stat Mode Mode Status Status Trap POE
1 Normal Forw Enable Auto 1000 Full Up Enable N/A
2 Normal Forw Enable Auto 1000 Full Up Enable N/A
3 Normal Forw Enable Auto 1000 Full Up Enable N/A
4 Normal Forw Enable Auto 1000 Full Up Enable N/A
5 Normal Disa Enable Auto Auto Down Enable N/A
RP Normal Forw Enable Auto Auto Up Enable N/A
SP Normal Disa Enable Auto Auto Down Enable N/A
(XXXX-Standby) >show port summary
Mikey
You don't have them attached to a Nexus, right? I once had really weird issues because of that (wlc crashed and reload loop).
Nope, these WLCs are connected to Dell C150 series switches.
Cheers
Mikey
Make sure that the load balancing is src-dst-ip. That is what the controller uses
-Scott
I know they are Dell switches, but could you check again the port configuration? Maybe there is some difference in the individual port configuration, which is overriding the LAG. I doubt this though and suggest opening a TAC.
You did once try to reboot the standby by hand?
Leo Laohoo
Redundancy Port is "UP".
What firmware are both units running on? Maybe they are running different versions.
Hi Leo,
If they were on different firmware versions, they wouldn't have been on active/standby role with the first two LAN ports active. right?
The WLC goes into maintenance mode only when I enable the remaining two LAN ports towards the switches.
Both the WLCs are running the same firmware version. See output below.
Active WLC
(XXXX) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.8.120.0
RTOS Version..................................... 8.8.120.0
Bootloader Version............................... 8.5.103.0
Emergency Image Version.......................... 8.5.103.0
OUI File Last Update Time........................ N/A
Build Type....................................... DATA + WPS
Standby WLC
Cheers
Mikey
Besides the problem, do you really hit more than 1.5 Gbps in one direction on the WLC, or why do you want to add the other two ports?
Just asking, because here with ~3000 simultaneous users, I rarely have more than 1 Gbps of throughput (spread over > 150 APs).
