Cisco 3600 aios can't set power higher that 2dbm
thefranmanatt
Anyone ever seen this problem?
not working 3600e(config-if)#power local ?
  <2 - 2>  One of: 2
  maximum  Set power to allowed maximum
Instead of
  <2 - 23>  One of: 23 20 17 14 11 8 5 2
CCNP - Wireless
CWNA and CWAP
CCNP - Wireless
CWNE #136
8 Replies 8
Scott Fella
Have you tried to set the antenna gain first then see if the allowed power is available.
-Scott
yeah,  I have also defaulted the AP.  no luck.  Power on the switch port shows 15.4 also
CCNP - Wireless
CWNA and CWAP
CCNP - Wireless
CWNE #136
thefranmanatt
From show controller d1
Configured TxPower:             -4 dBm
Allowed Power Levels:           -4  dBm
Allowed Client Power Levels:    -4  dBm
Active Rates:
CCNP - Wireless
CWNA and CWAP
CCNP - Wireless
CWNE #136
What does this show when you issue the command:
show controllers dot11radio 0
show controllers dot11radio 1
Never mind... Didn't see your other post
-Scott
Scott Fella
You see this on d0 also, -4 just means 40 MHz.
-Scott
I openned a tac case.  The eng is saying "that's odd".... never a good sign.
CCNP - Wireless
CWNA and CWAP
CCNP - Wireless
CWNE #136
Viten Patel
What is the code running on the AP?
