cisco 3702i - Transmit Power Level concept
CiscoWiFiGuy
Hello Experts,
I Just want to ask you regarding transmit Power level setting for Cisco 3702i access point. For some Testing of WLAN Signal coverage Mockup in my my porject , i converted cisco 3702i from LAP to Autonomous.
Now as per data sheet , i can see Cisco 3702i max transmit power in both bands is 23dbm in 2.4 and 5 ghz. when i configured it as autonomous , i configured both bands to use maximum tx power which i suppose to be 23dbm.
but when i look at overall stats , its showing me that i am using 16dbm on 2.4 and 17dbm on 5 Ghz. so can you please tell me how can i test its coverage area with maximum power which is 23dbm.
i checked sh 802.11 controllers command also , all my a,b,c,d antenna is up and for 5 Ghz all antennas are up and showing all ofdm.
So can you please guide me why its happening and i am unable to use max power even manually check-mark on "max Power" option in configurations.
It's not going to show you total power. If you have all four antennas, the most you would see is 17 which is equivalent to a total power of 23.  So 16 is because of the country and the channel.
-Scott
-Scott
Scott Fella
Maybe this spreadsheet will explain your max TX power as it depends on antenna also and channel (5ghz)
https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/channels/lwapp/reference/guide/3702e_3702i_pwr_chn.xlsx
-Scott
-Scott
Dear Scott,
In that spreadsheet , i think for 2.4 Ghz there is no information with 4dbi antenna.
The environment in which i have tested was very ideal environment in terms of WLAN Interference Performance. I configured least congested channel as my setting and there wasn't any source of interference during testing. but still i am scratching my head , y i didnt got 23dbm as my max tx power instead i got 16dbm.
-Scott
-Scott
Dear Scott,
Thanks for your inputs. I also got one very valuable link , which can be used to better understand the power levels also.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/channels/lwapp/reference/guide/lw_chp2/1140_chp.html#wp1158612%0A
 Also Please see the attached screen shots , just for your information ;for both bands. I am using this access point ( 3702i-E-k9) in UAE Region. so please correct me if I am worng ; referring to above link and my snapshots , does that means that in any case ,using access point in this region , I will have maximum of (40mw access point tx power on 2.4Ghz and 50mw access Point tx Power on 5 Ghz band).
* for 2.4 Ghz , 16dbm = 40mw
*for 5GHz , 17dbm=50mw
Have a Nice Day!
cheers,
