05-17-2015 12:34 AM - edited 07-05-2021 03:14 AM
I have two Cisco 4400 Wireless Controller. one is working fine but the other one is not reachable. Kindly advice how to troubleshoot.
Controller: - 4400 Series
Model: - 4404
Software Version - : 7.0.250.0
Satheesh.
Solved! Go to Solution.
08-06-2015 05:54 AM
If that is the only output you get I think you will have to contact TAC
Dont know if the 4400's still are supported and if you have a contract on it?
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/end_of_life_notice_c51-634665.html
Maybe TAC has some way of troubleshooting or rebuilding the bootprocess or it will have to be replaced.
08-13-2015 03:55 AM
are you getting this issue after a software upgrade then check here
http://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63770.html
have you tried to boot options (using backup image)
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/107530-backup-image-wlc.html
05-17-2015 01:04 AM
Can you tell use what other troubleshooting you have done? There isn't much information for us to help you. Is the unit powered up and accessible via console? Is the ports up on the controller and in the switch? Can you ping the gateway from the WLC?
-Scott
05-25-2015 11:28 PM
Hi Scott,
Sorry for the delayed reply. itried connecting through the console below is the details.
Bootloader 4.2.112.0 (Mar 12 2008 - 19:38:43)
Motorola PowerPC ProcessorID=00000000 Rev. PVR=80200020
CPU: 833 MHz
CCB: 333 MHz
DDR: 166 MHz
LBC: 41 MHz
L1 D-cache 32KB, L1 I-cache 32KB enabled.
I2C: ready
DTT: 1 is 40 C
DRAM: DDR module detected, total size:512MB.
512 MB
8540 in PCI Host Mode.
8540 is the PCI Arbiter.
Memory Test PASS
It get stuck at this point. Kindly advice.
Satheesh.
08-06-2015 12:00 AM
Still i couldnt find a solution for the above issue.
Satheesh.
08-06-2015 05:54 AM
08-13-2015 03:55 AM
05-20-2015 10:11 AM
As we have not heard from you that what other troubleshooting you have done towards resolution.
Please go through the bellow link which can help you on some basic troubleshooting steps for WLC.
Here you go : http://www.cisco.com/c/en/us/support/wireless/4400-series-wireless-lan-controllers/products-tech-notes-list.html
05-21-2015 02:12 PM
Please refer to the configuration guide of Wireless controller:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70mobil.html
and below is the guide with the troubleshooting steps :
http://www.cisco.com/c/en/us/td/docs/wireless/technology/guest_access/technical/reference/4-1/GAccess_41.html#wp1001632
05-22-2015 03:32 AM
Check the basic configuration : http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70.pdf
05-22-2015 07:24 AM
